Where do you hook up speaker wire at on the motherboard
    Scholar:
  • 145 Answers
Should have a few color coated holes to plug it into. You want to plug your speakers into the Green hole :)
Hope this helps
Posted on Apr 15, 2009
A wiring hookup for sony am/fm/mp3/xm CDX-R5515X
Yellow is memory so it hook to the battery, RED is ignition, BLACK is ground. Blue is power antenna, if you have one. Left Rear GREEN is speaker positive, GREEN/BLK is Speaker Negative. Right Rear PURPLE is speaker positive, PURPLE/BLK is Speaker Negative. Front Left WHITE is speaker positive, WHITE/BLK is Speaker Negative. Front Right GREY is speaker positive, GREY/BLK is Speaker Negative. ORANGE is night illumination.
Oct 03, 2014 | Computers & Internet
How to connect front pannel ak32 motherboard?
Here is the pinout of the front panel connector.
aaxnqfcgbhsmaaaaaelftksuqmcc
The power switch connects to the PWR PT pins. The speaker hooks to the SPEAK pins (only the outer pins actually used). The HDD LED connector hooks to the HLED pins. There is usually one red and one white wire. The RED wire goes to the "+" pin. The power LED wires hook to the PLED Pins. There is usually a green and a white wire. The GREEN sire goes to the "+" pin. The GLED pins are for the SLEEP switch if you case has one. The RST pins are for the RESET switch wires (if your case has one). Hope that helps
Jul 30, 2014 | Shuttle AK32 Motherboard
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Keeps smokin out the bac when i hook it up
This entry reminds me of my first install. My friend and I would hook up stereos, not knowing what we were doing. We thought radios ran on smoke, and if you hook it up wrong you let the smoke out. (laugh). But seriously, if there is smoke coming out of the equipment STOP. Your equipment is malfunctioning or you have something incorrectly hooked up to it. If this is a subwoofer or speaker that is smoking, it is telling you the voice coils are getting hot and it is about to fail. Again, more than likely, faulty equipment (it's hard to jack up hooking up a speaker). Anyways, if it's an amp, check the wiring. If the amp is smoking that means that there is something shorting on the motherboard. Might be time to look for different equipment or use that handy dandy warranty. Hope this helps.
Aug 22, 2011 | Car Audio & Video
Hook up for the audio on the front panel
When you are looking at the motherboard with the CPU and memory slots on the right, the audio hookup is up on the edge of the motherboard on the left. It's the last set of pins in the upper left side of the motherboard. If you have an audio jack in the front of the machine, you should have an audio cable just hanging there somewhere that is not hooked up. Hook it to the audio connector that I described.
Jun 10, 2010 | Biostar K8M800 Micro AM2 VIA K8M800 uATX...
Ive got creative inspire T7900 7.1 speaker system attached to my pc.one of the speaker connections in sub-woofer is faulty ? the sub-woofer seems to be a sealed unit so cant take panel off to have a look...
Is this connecting to a sound blaster audigy 2 zs or xfi soundcard? or a motherboard onboard soundcard/ aftermarket Other than creative?
If connected to the creative card odds are the wire is bad. get a new one
If connected to a generic the wires for the speakers are proprietary and you have to go get 3.5 to 3.5 stereo cables to hook it up
Sep 04, 2009 | Creative Labs Inspire T7900 Computer...
Wiring
To hook up speaker's, is not that hard to do.
there are two wire's for speakers, one is the earth and the other is positive.
You will be able to tell by, one of the wire's will have two colors that will be the earth.
hook the wire's up to your speakers, it will not matter if you get them wrong.
you will not blow them, the speaker might be a bit low just swap the wire around.
do this to the other speaker and you will be fine!
Good luck!!!!
Jul 28, 2009 | 1991 Mazda 323
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
Computers & Internet Logo
David Payne
David Payne
