Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Problem with WD EXT Network HDD (1TB)
Hi there, I have a problem with my brand new WD external network HDD, i've done everything the manual told me to do but it still can't see the HDD. I'm using Windows 7 RC1 at the moment, and i'm not sure how to get it working, any help woul be appreciated, thanks
P.S: i've connected it to a Linksys WRT54G router, my laptop is connected wirelessly though, is that a problem? thanks!
  • 3 Answers
Have you set up the drive as shared on your network?
Posted on Apr 15, 2009
WD 1TB drive only shows up as a 10GB hard drive
WD has a courtesy Drive cloning tool from acronis. It's on their web sit under drivers. Don't worry about the "My Book" thing the file is labeled Acronis True Image WD Edition Software download.
http://support.wd.com/product/download.asp?groupid=132&lang=en
Apr 27, 2014 | Western Digital My Book Essential 1TB...
Cannot get 1TB WD MyBook to work on NetGear N600 Router
this link is quite illuminative
click here please
seems that drive configuration needs to be done when connected to pc first then after it's recognized, added to network router
May 21, 2012 | Western Digital Computers & Internet
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
My WD External Passport HDD is not accessible. The hard drive is shown in My Computer, but everything hungs up on trying to access.
Hi.
You have to install WD Smartware, which is located on another drive.
THen you will have access to it.
Otherwise the drive is damaged.
God Bless You!
Feb 05, 2011 | Western Digital 1TB My Passport Essential...
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
I have a brand new WD 1TB My Book delivered today not recognised
Pleaes open the Device Manager and right click on the Yellow exclamation mark.
Now, click on update Driver and select Install from Advanced Location.
Type the Location as C:\Windows\inf and click on Ok.
The Driver should be installed now.
Jul 13, 2010 | Western Digital My Book Essential 1TB...
1tb simpledrive will beep, click, but not work. No joy.
power source jack/plug might be the problem if it has been bumped about or if it was powered up and running before plugging in to the comp.....
i had the problem of my 1tb ext/hdd no longer being recognized because when i plugged it into my comp, the jack was live and not switched of at the wall. the only way i got it to work was to pull it out of the casing and switched it with the 320 ext/hdd i have as they are they same brand..just diff sizes. going to put the 320 into comp to become master drive as the internal is a measly 40g. i think i had burned out the connector pins on the power jack when it was plugged in live. i hope this is an idea for you to try.
Aug 24, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
Computer freezes on start-up when western digital 1tb external hdd plugged in to computer, computer starts fine with it unplugged. The hard drive can be plugged back in after start-up.
This is a known problem with these drives. Disabling USB legacy support in your Bios should solve the problem., it did in my case but at the expense of not being able to boot from a USB device. Definitley a problem with their enclosure or drive.
Ken D
Aug 11, 2009 | Western Digital MY BOOK HOME 1TB EXT...
WD 1TB USB 2.0 EXT HD - NOT RECOGNIZED
Hi First things first, is the light on the front still coming on? If not try a new power supply or moving the drive to a new shell as the problem is either in the AC adapter or in the shell.
If the light is on it only confirms that you have power, but first try a different set of USB ports and if that doesn't work try a different computer. If it works on the other ports, no biggy, use it there. If it doesn't and works on a different computer then it's likely your registry entry for the device is damaged, get back to me if that is the case. If it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried these suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Jun 03, 2009 | Western Digital My Book Essential 1TB...
Wd Hdd inaccessable
try to disable all firewall setings or antivirus...after try accesing frome ur command prompe if u can that the windows is blocking the hdd...uninstall any new software or driver and try again...no effect ok dowload ophcrack live cd frome google and access the hdd by force repare or scan it in surface scan that will fix ur clusters problems that might be in the back off this prob an du know wer e2 go frome there
Feb 12, 2008 | Cavalry Storage Cavalry CAUO37500 500GB...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
362 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
