Question about Visonik V1201A Car Audio Amplifier
Visonik V1201A 1-Channel AB Amplifier Problem
My amplifier quit working. It has a protection light and it is on. What do i need to do to find out the problem?
  • brandon12570 Apr 15, 2009
    Alright, i will try that. I personally didn't install the amp, I bought the car with it pre-installed.
  • Roberta Smith
    Roberta Smith May 11, 2010
    remove the power to it for about 10 minutes.... while you are waiting check the wiring to the speakers to make sure all connections are proper
    Brigadier General:
  • 5,158 Answers
In that case check all the wiring to make sure it is correct
Posted on Apr 15, 2009
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
My visonik v700hc keeps going into protect modeafter listening for a couple minuits then will go green light then back to red after a coupke more any solutions
I suggest checking what ohm load you're presenting to that amp. go to www.the12volt.com and find the subwoofer wiring diagram and choosing the amount of subs you have on it and then the impedence of each one. you're probably sending too low of an ohm load to the amp this would cause it to go into protection quite frequently and eventually stay in protection.
May 30, 2010 | Visonik V700HC Car Audio Amplifier
I can't seem to get out of protect mode. Any suggestions
Hi disconnect everything, inputs speakers and leave power. If still in protect mode then there is a circuit problem, will have to send it in.
Best of luck
Jul 15, 2009 | Visonik V2508 2-Channel Amplifier
Visonik amp problem... amp goes in and out of protection
Check for intermittent shorts on the speaker leads.
Turn down the volume control on your head unit while operating the amp, you could be over driving the amp.
Remove Speaker leads and reset the amplifier. IF the protection LED still comes on amplifier is faulty.
Below is the link to put in a help request with the manufacture for repair.
http://www.visonikcaraudio.com/category.jhtm?cid=27
Mar 25, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Protection light on Visionik V204XT
What happens if you have the positive 12v wire from the battery connected?
Nov 16, 2008 | Visonik V204XT Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
Visonik V1201A Car Audio Amplifier Logo
97 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
