Question about Wolf Range Kitchen Ranges
Wolf Dual Fuel 36 in range. Oven door won't latch closed.
Wolf Dual Fuel 36 in range. Following self clean mode and after the oven cooled down the oven door will not latch closed so the oven can't be used. I briefly recycled the self clean mode, to test operation of the oven door lock, and it locked successfully then unlocked when self clean cancelled but the oven door won't latch in normal cook mode. Can you please offer any suggestions/fixes. Thanks a lot.
devocap
  • 201 Answers
SOURCE: Admiral electric range with self cleaning oven
Hey there gcato1, your problem is actually a protective feature designed to prevent you from getting burned. The self cleaning feature runs at extremely hot temps. Until the temperature reaches a safe level, the oven door will remain latched. Be patient and the problem will solve itself.
Posted on Jan 29, 2008
  • 135 Answers
SOURCE: Dacor ERD36SCH/H will not self clean
Door lock motor suonds like it is bad. Not an easy part to replace. You may need a technician.
Posted on May 13, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
  • 22 Answers
SOURCE: Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Posted on Mar 31, 2009
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Oven door won unlock
I HAVE A 10 YEAR OLD OVEN RANGE. SELF CLEANING IS IN THE LOCKED POSITION. I UNPLUG THE RANGE FOR 30 MIN THE DOOR IS STILL LOCKED
Jan 08, 2014 | Electrolux 30" Self-Cleaning Freestanding...
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
I have no owner's manual and need to know how to clean a "self-cleaning" over.
Manuals for many GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . You will need the model number and there is a guide to find the plaque at the site. Most ranges will have the plaque under the left front burner, on the frame behind the oven door, on the frame behind the drawer or on the left leg behind the drawer or kickplate.
General cleaning procedure for self-cleaning: first use hot soapy water (non-abrasive cleaner, not an oven cleaner) to clean the frame around the oven and the oven door itself. Also clean large spills (acidic and sugary spills can damage the surface of the oven). Remove all of the racks, foil, pans and the broiler pan from inside the oven. Close the oven. Ventilate the kitchen well. Then it depends on the oven type.
If you have a touch pad, press the Clean button and adjust the time for the cleaning cycle (usually with the +/- touch pads). Then press Start. Press Cancel to stop the cycle. The oven will automatically lock and remain locked until the oven cools down after the cleaning cycle. See the documentation for timed cleaning. If you have a dual oven, you will need to press the Oven button for the one you want to clean.
If you have an older range, push the latch to the right and set the Oven cycle dial to Clean. After the oven has cooled, turn the oven cycle dial to Off and push the latch back to the left.
I hope this helps.
Feb 18, 2011 | GE Kitchen Ranges
Iam using the self clean on the oven . Is there anything I need to know? Itook the racks out before starting the self clean.
Yes never use the self clean right before a holiday like thanksgiving.
99.9% of the time everything will be fine. The other time when you're going to need the oven the HSI will go bad a the oven will not relight. This happened to me. I love self clean. Do this on a cool day it will heat up the kitchen and kinda smell a little. Make sure all racks and cookie sheets are out, lock the door and hit the button.
Apr 18, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
THE OVEN DOOR WON'T CLOSE ALL THE WAY
I had this problem on my Wolf Dual Fuel oven after I removed the oven racks and oven rack supports in preparation for the self clean cycle. Wolf recommends this removal to avoid discoloration of the racks due to the extreme heat.
After cool down I re-installed the racks and the door wouldn't close fully. I messed around for quite a while, everything looked fine but then noticed that the rack support on the left hand side of the oven was not correctly mounted on the support studs/screws on the side of the oven wall. There are 4 keyhole slots on the rack support that have to aligned correctly with the studs if they're not the racks interfere with the fit of the door.
Bob
Apr 11, 2009 | Kitchen Ranges
Wolf oven self-clean error 01
Well, ours is working now. We called Wolf, they said the Error 01 indicated a problem with the latching mechanism (that locks the oven during self clean).
We called the local repair outfit (they've been here several times before working on this range), they ordered a latch mechanism and arrived today to install it. The tech this time had worked at an electronic company that I also worked for about 10 years ago (I'm an electrical engineer). So we had a good time talking about the old days and working on the range - I'm always curious about such things. We removed the latching mechanism - its an assembly with a motor and a couple of switches that are used to start and stop the motor. We tested the switches and motor using a meter and power cord. Seemed to be OK. The next thing would be the control board - which we had replaced about 3 years ago - under warranty. Before removing the control board we reinstalled the latch mechanism - and, of course, everything worked fine.
We were both a little dismayed about the quality of the assembly of the range - the wiring looks more like a rat's nest than the tidy routing that we'd like to see.
So, bottom line, neither of us knows what the problem was. Could have been a food particle lodged in the switching mechanism, an intermittent connection or ???.
One thing I noticed as we checked out both ovens: We put the small oven (the one that was having problems) in self clean for a couple of minutes - was OK. Then we turned it off and turned the larger oven to clean mode - when we did that, "OPP" appeared on the display. The tech said that was because the latch of the smaller oven was not in its stop position yet. We gave it a few more seconds then tried clean mode on the other oven and it was fine. I mention that because OPP appeared on the small oven once or twice when we (my wife and I) were initially trying to figure out what the problem was. There's probably a hint in there somewhere as to what the real problem was.
At any rate, its working again ($115 later) but I'm not real confident that it will continue. Next time, I'll open it up myself (not recommended). <g>.
Oct 18, 2008 | Kitchen Ranges
Need to know how to operate the self cleaning on my amana gas oven
Close the oven and the associate latch ( near the handle) then select the self cleaning option on the control.. Let it run thru its cycle.. when it is complete and cooled down enough.. the door latch will release and allow entry into the oven.. Hope that helps..
Aug 28, 2008 | Amana Kitchen Ranges
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Kitchen Ranges Logo
401 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Steve F
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
