Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Water sitting in bottom of dishwasher
Dishwasher has water sitting in the bottom after cycle is finished
  • 1 more comment
  • tbgraphics Apr 22, 2009
  • stevege68 May 03, 2009
    Dishwasher will be running (any cycle) and I'll come back in later to see if things are finished. Cycle lights are still on and when the door is opened, there is still a lot of water sitting in the bottom (as if one of the cycles stopped right in the middle and never finished or moved on to the next cycle.
  • luv2garden12 May 19, 2009
    With the water sitting in the bottom of the dishwasher the 'Heated Dry' cycle creates copious amounts of steam that never evaporates. It condenses on the door and the sides of the dishwasher as things cool which creates an environment rich for mildew. I am not happy about this at all and want to know how to get the water to drain thoroughly.
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: Dishwasher--water in bottom -end of cycle.
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Posted on Feb 26, 2008
futureloginn
  • 734 Answers
SOURCE: Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Dishwasher is leaking and backing up with water
Sounds like the door gasket is leaking allowing water to come out
Posted on Apr 29, 2009
Why isn't the dishwasher tablet melting?
Two possible problems
- You may have a problem with the water heater.
Tablet need to reach a given temperature to be dissolve
- Check if the water arm do turn ans spay water. To test, turn to a fix position, start the dishwasher and open after the the start of the cycle. Open the door and check the position of the arms.
If one of the arm is not turning, check the water holes One of them may be blocked
Oct 18, 2016 | Dishwashers
How do we remove the horrible smell in our Bosch dishwasher?
First check out your model to see if it has a built in garbage disposal, if so, make sure it is not mucked up.
Run hot water down your sink drain while running the sinks garbage disposal. Pour baking soda down your sink garbage disposal followed by white vinegar. Let it sit and foam. Run hot water down sink disposer while running. When finished:
Run empty dishwasher with no soap, let dishwasher fill with hot water to wash and then pour 1 cup of white vinegar into the bottom and resume wash. Make sure you take it through the dry cycle. When finished, open dishwasher and let it air for a couple of hours, longer if you live in humid area. Hope these steps do the trick.
Aug 03, 2014 | Bosch Dishwashers
Check float valve
pull out your bottom rack, in one of the bottom corners of your dishwasher there will be a circular plastic piece. it is probably stuck in the up position . Wiggle it around, it should sit loosely in place. It's a float, so when water fills in your washer, the float should raise up, when the water is draining, the float should lower with the water. That's why the float should be sitting loose in position.
Dec 29, 2013 | Maytag Dishwashers
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
There is water sitting in the bottom after all the cycles finish I tried to cancel and rinse to no effect.
9 times out of 10 there will be debris stuck in the pump impeller... access from the bottom of dishwasher by tilting to side or back... common fault...
Oct 03, 2010 | KitchenAid KUDR01TJ Dishwasher
Detergent packs are not dissolving
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 21, 2009 | KitchenAid 24 in. KUDS02SRSS Stainless...
Bad Smell
start your dishwasher with no dishes in it.
Let in run until it takes on water and start washing.
Then open the door and pour in 8 oz of white vinegar and let it finish the cycle.
If this does not correct the smell...purchase the AFFRESH product and use that.
Mar 12, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
196 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
