My laptop turns on but I cannot hear the disk run and the screen is blank.... please help me urgently
Not sure on this for sure but it sounds like what the dv6000 did or does and the motherboard needs replaced.
SOURCE: cant play a dvd on laptop hp pavilion dv4000
check ur software that plays ur disks e.g.media player when first installed needs dvd media to be enabled.sounds to me that software is not enabled or codecs are not installed.if it plays cd's ok there is nothing wrong with ur drive whatsoever its a software issue.theres dvd player software at the hp site free to download includes all codecs and plays most media called windvd.
SOURCE: How to adjust the brightness on a HP Pavilion dv4000 laptop scree
Its usually the Fn key (bottom left) and a function key on the top line like F1 to F12 the brightness is the picture of the sun. I couldnt find any specific information on your model but most HP's are the same.
SOURCE: hp pavilion dv9000 screen and factory settings
*Actually*, with regards to the screen issue, software CANNOT cause a failure when the display assembly is physically moved....The two possibilities are the LCD harness (video cable) part# 432962-001 OR the actual LCD itself (part# LP171WP4 (TL)(03) for most models). My money's on the cable, not a stupid driver...
SOURCE: when i on the hp pavilion dv4000 it is just blank
go to safe mode by press F8
start>run>type "msconfig"
select service tab
remove all tick mark
apply
ok
restart
SOURCE: i want to rebuild my HP Pavilion dv4000 laptop but no disks.
Hello, my name is Israel and I will try to help you. You may be lucky and won't need them. HP has been kind enough to put them in the harddrive. First you will need to be sure you have saved any files that you want. If you need to you may have to try to start it in safe mode. Using F8 at start up will get you into safe mode. If your computer cannot start in safe mode and you just want to redo the whole thing, then at start up press F11. This will get to the restore program and follow the directions. Good Luck.
