Turn on DVD power and Aiwa name screen is not displayed on television. rather it is just snow. no picture when dvd is playing. just snow. even though no loose connections. please help
  • mmiddlen Apr 15, 2009
    all ready connected to television. no issue there.
    issue is upon turning power on. it has worked fine in the past until just last week.
  • cebuwano May 11, 2010
    are you trying to connect a dvd player into your tv set? do you have video input jack on your tv? what is the brand and model # of your DVD and TV?
  • 63 Answers
I assume that your connection between tv and dvd is using an rf modulator. that means you dont have video input in the tv. if this is the case, set the tv channel to channel 3 or 4. let us know.
Posted on Apr 15, 2009
Green snow
A greenish tone to entire display denotes a faulty panel. If you wish to get more details to this, check the site linked here. It has screen-shots to faulty plasma display. You can see it and compare to that of your TVs' and can make sure. Pull up older posts. Good Luck.
Nov 27, 2013 | Panasonic TH-46PZ800U Plasma TV
Tip
Samsung DVD-HD850, DVD-HD841 region free code
1. HDCP-Free: Requires only DVD Remote.
a. Power On DVD player, no disk inserted
b. Press "Angle"
c. Press "4", "3", "2", "7"
d. Press "Angle"
e. TV Screen displays HDCP Free
2. Region Free Hack: Requires AIWA/Universal Remote or PDA
The following instructions are for a Pocket PC
a. Download and install TvRemote
http://www.pdawin.com/tvremote.html
b. Download AIWA Mini Audio CCF file
http://www.remotecentral.com/ftp/ccf_templates/mini_systems/aiwa-mini-nsx999.zip
c. Copy the unzipped CCF file to your PPC
d. Run TvRemote on your PPC.
e. Switch to CCF mode on TvRemote
f. Open the copied CCF file. Screen changes to display
the remote.
g. With DVD switched on but tray closed:
i) Press "Repeat"
ii) Press "Program"
iii) Change remote screen and Press "Clock"
DVD display shows "ADJUST"
iv) Press "9" on DVD remote. I also pressed "9" on the
PPC remote so I'm not sure which one did it.
v) No visual indicators occur on DVD.
vi) Power off DVD.
h. DVD is now region free!
on Mar 07, 2010 | Televison & Video
My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
Aug 30, 2012 | Televison & Video
There are marks on my LCD 42" TV ,its on the screen itself.It looks like water marks.It started of small marks and it then it getting bigger.
Things You'll Need:
  • Burn-In Reduction Screen Saver DVD
  • DVD Player
  1. Instructions
    • 1 Plug DVD player into your TV and power on. Make sure you plug the right component cables into their corresponding inputs on the back of the TV. This is usually done by simply matching the colors of ends of the cables with the colors of the input holes on the back of the TV.
    • 2 Turn TV to the proper input to display the DVD. Make sure there is not a DVD in the player.
    • 3 Place burn-in reduction screen saver DVD in the player. Allow a few seconds for the DVD to start playing. A pattern of white "video snow" will appear on your screen. The entire screen should be taken up with this patterm.
    • 4 Run the DVD for at least several hours; this will help wear the TVs phosphors evenly. Depending on how long the image has been burned into the screen, the amount of time you should play the DVD varies a lot. A good rule to follow would be to play the DVD at least four times the period the image has been displayed. If you have an image that has been on the screen two hours a day for a whole month, run the screen saver for at least 240 hours
Jan 17, 2011 | Televison & Video
Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Aug 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Dvd plays upside down how to play normaly
To rotate the DVD screen display, hold down the MODE button or DISPLAY MODE button (depends on model) while a DVD is playing to turn the picture right-side up.
Mar 27, 2008 | Polaroid Portable DVD Player PDM-0822BD
Problem with a Hitachi model number 57F710E Model....
sounds like a bad convergance chip/board. But with it working ok on the DVD it may be a tuner problem. If the DVD is hooked in the video plug, you may way to run your channeling from the DVD and foget the tuner on the TV. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 12, 2007 | Hitachi 57F500 57" Rear Projection...
Snow screen
Your symptom is not a normal failure symptom. Can you be more specific? Is this on all inputs?
Oct 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can't Get Any TV picture on mySharp 27DV-S100 TV-VCR-DVD combo
open back up the set and look closly at all of the plug connections and cables as you might not have pulled one out all the way but may have in inadvertantly pulled on a cable of one of them and pulled one out have way or just a little. My freind it happens to the professionals all the time. Make sure you check all the plugs on the VCR as well as the tv that they are instraight and flush. Good Luck Ps Please dont forget to rate this.
Oct 15, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
