A/c port low side 96 chevy tahoe
I have a 1996 chevy tahoe and I need to know which port on the a/c is the low side. When looking at the compressor I see 2 black caps, one pointing up (left side), I see one pointing at me (right side).
  • 3,361 Answers
The largest hose is the low side.
Posted on Apr 15, 2009
The small valve is the low side (to recharge freon), the big one is the high
Posted on Jul 03, 2009
I have a 96 chevy tahoe it starts but will not move in drive or reverse whats wrong?????
is the transfer case shifted into neutral?what if you move it down to low gear?is there fluid?
Jul 12, 2012 | 1996 Chevrolet Tahoe
Trying to recharge my A/C in chevy tahoe 2000 cant find the valve where i need to attach to.
The low pressure side port is located somewhere on the 'thicker' plumbing vs. the 'thinner' plumbing coming off of the compressor.
The pressure should be 25psi to 45 psi when the compressor is running.
You can't connect the low pressure hose with a can of r134a on the wrong side (high side vs. low side) because the ports are a different diameter (size).
It may be on the accumulator as well, the canister looking part of the a/c plumbing.
Aug 19, 2010 | 2000 Chevrolet Tahoe
96 chevy blazer not blowing out cold air only 70 deg.freon full clutch engage and disengages
Have you checked the low side and high side pressures? The compressor might be bad. Does one line to the compressor get cold and the line coming out get hot?
Jul 02, 2010 | 1996 Chevrolet Blazer
Location of low pressure port of a/c system on a 96 ford thunderbird
Here is a system overview. The low side port is #5 in the picture. Hopw it helps ya.. Cobra
Item Part Number Description 1 19972 A/C Compressor to Condenser Discharge Line 2 19E762 A/C Charge Port Valve(High Side) 3 19D594 A/C Pressure Cut-Off Switch 4 19D742 Evaporator to Compressor Suction Line 5 19E762 A/C Charge Port Valve(Low Side) 6 19E561 A/C Cycling Switch 7 19860 A/C Evaporator Core 8 19C836 Suction Accumulator/Drier 9 19835 Condenser to Evaporator Tube 10 19D734 A/C Manifold and Tube 11 19703 A/C Compressor 12 19712 A/C Condenser Core
Jun 12, 2010 | 1996 Ford Thunderbird LX
Where is the low port side on a 96 grand am?
Most of the time they are on the underneth,of the engine compartment on passengers side,on the rear of the ac compressor on the low side line,Find the ac compressor,and follow the large ac line coming from it,and it will take you right to it.
Jun 05, 2010 | 1996 Pontiac Grand Am
Which is the low side service port for a/c on a 2002 chevy tahoe
The port on the larger of the 2 A/C lines coming out of the compressor is the low side.
Apr 24, 2010 | 2002 Chevrolet Tahoe
Air conditioning compressor not getting power on 96 Chevy Tahoe
Freon is what you are missing, our more specificly a refigerant charge that exceeds 45psi on the low side pressure line. This system has two pressure switches, a high side cut-out switch mounted on the rear of the compressor, and a low side or pressure cycling switch on the suction line.
Jump the low side switch contacts to ensure the electronics are sound for this system. If the compressor cycles, you know the system is low on a refrigerant charge. Turning on the AC is a request, and certain criteria must be met before the system operates as designed. Good luck
Mar 12, 2010 | 1996 Chevrolet Tahoe
Where is the low pressure line service outlet located 96 lumina apv
They can hide these pretty good,you may not like this ,but here goes.Find the ac compressor ,and follow the large ac line/hose that comes off of the ac compressor.It will take you to the low side service port.It will be the small port.Most of the time it is located on the dryer,or near it,but not always,but it will be on the large line of the ac system.If I can help ,let me know.>>.roniecon@gmail.com
Sep 23, 2009 | 1996 Chevrolet Lumina Mini
96 Tahoe no Cold Air
YOU NEED 28 PSI ON LOW SIDE AND ABOUT 190 ON HIGH SIDE.YOUR REFRIGERANT IS LOW THAT WHY COMPRESSOR CYCLING ON AND OFF.
Jul 22, 2009 | 1996 Chevrolet Tahoe
97 grand am low pressure port to recharge
The low pressure port is on the compressor on the bottom side. It should have a black cap on it.
Jul 24, 2008 | 1996 Pontiac Grand Am
Heating & Cooling Logo
1,112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
