Question about Turbo Air 72 cu. ft. / 2039 liter Commercial Freezer TSF-72SD / TSR-72SD
Freeze will not run doors heat nothing else
Will not run at all control board has capacitor swollen at top and leaking wax looking stuff
    Scholar:
  • 136 Answers
That is known as a puffed capacitor and usually indicates a power supply problem as well. The cap can be changed with a 50/50% chance to work again unless it took out other components.
Posted on Sep 14, 2007
SOURCE:
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
My freezer seems to turn itself off. The number panel is blank and it will run nonstop or the number panel looks funny and it is not running at all. Also it will just turn itself off, light and all. I...
In all likelyhood, the control panel has a bad capacitor. You can check it and replace it yourself if you have a soldering iron. If the control panel looks like this:
You can remove it by unplugging the freezer, then carefully prying the unit off the front of the freezer with a screwdriver. There are several tabs holding it in place, be careful not to break them.
When you get the unit out, turn it over and inspect the capacitors (the three round things attached to the circuit board):
If you look carefully, you will notice that the top and bottom capacitors are flat on the top, and the one in the middle is bulging up. This indicates a blown capacitor. Another view:
If one or more of your capacitors is bulging or leaking, that's your problem.
The circuit board is held in place by four tabs; place a small flat screwdriver in the slots (visible just to the right of the green resistor in the photo above) and use another screwdriver to push back the tab holding the board in place. Once you get it free, go on to release the other 3 tabs. Carefully remove the board.
Once you have the board out, you can use a soldering iron to melt the solder holding the bad capacitor in place and remove it, then you will have to obtain a replacement capacitor (Radio Shack sells them for about $2.) and resolder it back where the bad one was. The ratings for the caps are printed on them, the typical value for the larger one is 1000uf @ 16V, but I would recommend using a 1000uf @ 25V - 35V, as the original is prone to fail. The two smaller ones are typically rated at 220uf @ 50V.
The circuit board is coated with a layer of sealer, so you may have to sand the tiny soldering pads before you can resolder the part back in. Be sure to put the cap back in the proper orientation; the circuit board is marked with a + where the positive (longer) lead should go, and the cap is marked with a - on the negative side.
Put the board back in the plastic holder (make sure it's right side up) and reinstall. Plug the freezer back in and it should work.
NOTE: If the capacitors are not bulging or leaking, they are not your problem and this will not fix the issue.
Oct 26, 2013 | Frigidaire FFU14F5HW 13.7 Cu. Ft. Upright...
25328782800 freezer not freezing 2 lites blinking
The problem your refrigerator has sounds like a 297370602 Main Control Board
Can you unplug refrigerator and go into the control panel inside the fresh food section? Examine the board for burn marks and swollen capacitors. I will be here if you have questions, Sea Breeze
Feb 08, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Stuff on top shelf wont freeze
There must be a leak at the top to allow air in. I am assuming the rest of the freezer is fine. Do you find frost on the ice trays. Check the seals on the doors.
Feb 01, 2013 | Midea Freezers
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
My hotpoint under counter freezer isn't freezing properly
A freezer has a very simple operating design and there are only 2 customer serviceable components.
1. Make sure the cold control is set at the proper level.
2. Make sure that the door seal is making good contact with the cabinet. You can apply a thin coat of Vaseline to the door seal to help tight closure of the door.
Keep the door opening to a minimum during extreme heat conditions. Any small air leak can drastically reduce the operating norms during extreme heat conditions.
That's about all that you can do to regain control, the rest will have to be performed by a refrigeration tech. if you are still dissatisfied.
Jul 05, 2009 | Amana Freezers
Ice is forming at the bottom of the freezer and freezing the bottom draw shut. it doesn't appear to be leaking and the door shuts properly. it's supposed to be a frost free freezer....
Causes:
High humidity in the immediate area causing condensation to freeze at the door opening
A frozen defrost drain line not allowing water to drain off when the unit is in defrost
A bad door gasket causing an air leak
Some freezers have a heated perimeter to reduce condensation. If the stop working, moisture can accumulate arounf the door perimeter and freeze.
Leaving the door open too long or something obstructing the door
Mar 28, 2009 | Freezers
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Turbo Air 72 cu. ft. / 2039 liter Commercial Freezer TSF-72SD / TSR-72SD Logo
143 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Felizardo Erilla
Felizardo Erilla
Todd B
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
