Question about Tomtom One Europe v2 GPS Receiver
Problems with voice assistance?
I have only just received my TomTom & set it up. However the voice assistance was distorted to start with, then now it seems to have gone altogether? Plse can u help me out? Is there poss a problem with the speaker or something else? M Purdy
  • dkb1 Nov 06, 2007
    no sound
Try turning the volume down.
Posted on Sep 23, 2007
SOURCE:
Tomtom one won't go past voice person. It keeps starting over.
You have installed a NavTones GPS voice that is encrypted to a different device code (serial number).
  1. connect TomTom to PC
  2. navigate to 'voices' folder
  3. Delete any recently installed voices
  4. Disconnect and restart
Aug 04, 2011 | Tomtom ONE GPS Receiver
Unit is one year old. Worked fine this morning, got back into car and GPS asking set-up questions but a the time prompt it flashes off and starts the set up over againi with language prompt. Keeps...
try this originally posted by gt3rs i just did it and it worked for me Here is a solution that worked in my case (constant reboots after voice select)
  1. Plug your tomtom into your PC.
  2. Run TomTom Home
  3. Select the option to run your TomTom through your PC (TT Home)
  4. You should be greated with the select language screen
  5. Then simply select language etc.
  6. When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
  7. Don't panic TT Home should start working again in a few seconds
  8. Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
May 10, 2011 | Tomtom One XL GPS Receiver
How should i chage the language on tomtom to
Do you want to change the language of the VOICE or the WORDS IN THE SCREEN? These two are independent from each other and need to be set up by separate.
1) To change the VOICE, you need to download an ENGLISH VOICE.
a) Start TomTom2_bing.gif Home on your computer.
b) Plug in2_bing.gif the TomTom dock to a USB port on your computer and plug in your TomTom GPS2_bing.gif on the dock
c) Turn on the GPS and when asked "connect to computer" answer "yes" (you may not be asked if you want to connect; TomTom2_bing.gif Home amy detect your GPS and connect to it automatically). If your GPS is not connecting to TomTom Home, turn the GPS off, turn it upside down and press the "reset" button for 7 seconds, place the GPS back on the dock and turn it on. It should automatically connect to TomTom Home now.
d) On the TomTom Home software, click on the icon labeled "Add Traffic, Voice, cameras..."
e) Click on the icon labeled "voices"
f) Click on the icon labeled "computer voices"
g) Click on any of the voices that says "English" on the second ("language") column; download and install the voice
h) Go to the TomTom Home top menu and under "DEVICE" choose "DISCONNECT DEVICE". Wait a few seconds until the GPS communication with the computer is broken and the GPS restarts. You don't need the computer anymore for now
i) On your TomTOm GPS, tap on the middle of the screen to bring the menu.
j) Touch "CHANGE PREFERENCES"
k) Touch "VOICE PREFERENCES"
l) Touch "CHANGE VOICE"
m) Select any of the voices that are in English (such as "SUSAN, English US, Computer"). After this, you can TEST the voice. Check that you can hear the voice, otherwise, you'll need to adjust the volume. We'll do this later. Touch "SELECT" to select the voice. Press "DONE" on the next 3 screens until you're back to the GPS navigation screen
n) To change the volume, tap on the LOWER LEFT rectangle. You'll get a VOLUME SLIDE. Slide it to the RIGHT to increase the volume and to the LEFT to lower it. I keep mine around 85% volume. YOU ARE DONE SETTING UP A NEW VOICE
2) To change the LANGUAGE of the WRITTEN DIRECTIONS on the screen:
a) On your TomTom GPS screen, tap on the middle of the screen to bring the MAIN MENU on
b) Tap on the PREFERENCES icon
c) Tap on the RIGHT ARROW 7 times or until you see an icon labeled "CHANGE LANGUAGE".
d) Using the UO and DOWN arrows on the GPS screen, scroll up or down untill you see the langauges you're looking for. You'll get a screen with several languages available, including "English UK" and "English US"
d) Touch on the screen you want. The screen will automatically go back to the previous menu screen that shows the "CHANGE LANGUAGE" icon. Touch the "DONE" button.
YOU ARE ALL DONE. Now, your VOICE and all WRITTEN DIRECTIONS should be in ENGLISH.
If this didn't work, please report back so that I can provide further assistance
Mar 21, 2010 | Tomtom GO GPS Receiver
Voices do not work
i have solved this problem before please refer to my name and look up my solved problems and it will help you
May 17, 2009 | Tomtom ONE GPS Receiver
Setting up voice recognition on my 920t
voice recognition should be set up by default on the unit you describe. in order for it to go into voice recognition ou need to do navigate to the spoken address
Dec 27, 2008 | Tomtom GO 720 GPS Receiver
Set up voice John Cleese
You need to put the File / files associated with the voice onto your SD card in the Voices folder.
Use an SD card reader and your PC to look on the TomTom SD card. Find the folder called "VOICES". Copy the John Cleese voice files into the "VOICES" folder.
Once this is done put the SD card back in your TomTom. Switch on. When the TomTom starts up , tap the screen and select "Preferences" , then move through Preferences until you find "Lips" icon and under that it will say " Change Voice" . Tap the Lips Icon , then move right or left until you find the required / John Cleese Voice and select that. Your Tom Tom should now give directions with the John Cleese voice.
Please note: Some voices that you can download free of the internet can contain viruses or if you are unlucky they can contain faulty data which can effect the workings of your TomTom.
As a precaution , before you copy or alter or add anything to your TomTom SD card you should make a Backup of your SD card onto a PC. The if anything gets upset on your SD card you can always format it and restore the origonal data.
Good Luck.
Sep 08, 2008 | Tomtom ONE GPS Receiver
Installing Tomtom voices
You can look in the tomtom voices directory with windows explorer while tomtom is hooked to the pc, be sure the voices files are in the voices directory on tomtom.
Jul 22, 2008 | Tomtom ONE 3rd Edition GPS
Cannot Hear Tomtom Voices
yeah you need to go into the settings and activate the voice audio, sounds like its been switched off!
Dec 26, 2007 | Tomtom ONE GPS Receiver
Voice not working properly on garmin nuvi 660 - very disdorted
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
Dec 03, 2007 | Garmin Nuvi 660 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
35 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
