Question about Samsung SGH-D600 Cellular Phone
It keeps restarting on its own
Randomly one day it switched off, then within the week it would switch off more regularly until its at the point where when i switch it on, it does the opening theme then automaticaly the closing theme, sometimes it wont even switch on. i took it to be fixed an they said it wasnt the phone, must be the battery. i baught a new 1. two weeks later, same problem. please help.
    Problem Solver:
  • 10 Answers
No its due to corrupted software it should have to be reinstalled if its under warranty go claim it else fin nearest service center and have it reinstalled it shouuld cost you only about $75
Posted on Sep 23, 2007
SOURCE:
96 chevy silverado diesel randomly dies and usually restart immediatly, 2 days ago replaced ignition solenoid and now glow plug light on dash wont come on. checked fuses, they are all good. Truck runs very...
for diesel to stop it has to be a fuel related problem
it will not be fuel flow problem as it restarts immediately so it will be an electrical problem connected to the stop solenoid
the stop solenoid is a power on at all times until the ignition is turned off at which point the power is cut and a spring in the solenoid pushes the plunger to the no fuel position
logically that would point to a broken wire but even that is not the answer as it would not restart immediately
which points to contacts in the ignition switch
if the contacts or wire on the back of the switch is faulty , then the power to the solenoid could put through a high resistance in the switch points /contacts and that drop in power would trigger a stop situation
recycling the switch makes for a good contact for a period
I would be spending time in the switch and harness connections to the switch
Jun 04, 2017 | Cars & Trucks
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
Dish vip 622 and vip 722k frequent picture freeze and restart
Sounds like a signal strength issue. You may have either a low signal or something like a tree limb is blowing into the signal path dropping the signal strength to a point low enough to causes issues.
Apr 13, 2010 | Televison & Video
My new eMachine keeps crashing. I walk away with items open and when I come back, it has done an unscheduled reboot - like someone walked by and pulled the plug except it does come back on on its own. ...
Open Control panel (switch to classic view). Double click on "Power Options" (green cell in Vista) and select 'High Performance'.
If its already set to High Performance settings, inspect the cables especially at the jacks as they may be loose.
You have to make sure the electricity does not cut randomly and if it does, use a UPS (with adequate rating eg 400 Watt PSU needs 400/06=650VA UPS) or an inverter.
When the PSU (power supply unit) is failing it can cause the system to restart randomly until it fails completely taking away the motherboard with it.
At this stage you should not open the case but try the steps I have suggested.
Note that in addition to the above a software conflict may be forcing the system to reboot. If the problem persists, contact E-machines as you are within the official 1 year warranty period.
Mar 31, 2010 | E-Machines eMachines Desktop PC
2003 mazda mpv stalls several times while driving, all dash lights come on, need to coast to a stop, problem occurred once a week for three weeks and then happened three times within a mile, re-started...
i would ask the mechanic to check the ignition switch for pitting ....i had this problem with my honda accord for a long time until i finally just switched it for the second time and sanded it down to the point that it would touch but not keep contact to make the pitting .... hope this helped
Oct 29, 2009 | 1990 Mazda MPV
Audi a4 2002 radiator fan keeps randomly starting
it could be a faulty fan switch, or faulty engine coolant temp sensor or a faulty fan relay
Feb 16, 2009 | 2004 Audi A4
Samsung SGH-D600 Cellular Phone Logo
78 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
