Question about Lexmark Wheelwriter 15 Series II Typewriter
Typewriter will only print top half of letter.
I tried putting in a new ribbon but the same problem occurred.
  • Lexmark Master
  • 3,594 Answers
Sounds like the platen (black rubber roll) isn't fully seated in the side frames. Press down firmly on both ende of the platen it should snap into place.
DickyO
Posted on Apr 18, 2009
Typewriter is only typing the top half of each letter- changed ribbon- still doesn't type the bottom of the letters ???
typing the top half of each letter Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Mar 31, 2016 | IBM Wheelwriter 30 Series II Typewriter
Printing on the top half of the characters
Is your platen snapped down all the way? Can you look at the ribbon and see where the letters are striking the ribbon?
Apr 01, 2014 | IBM Office Equipment & Supplies
The lift-off tape is to low
1. Use the SPACEBAR or BACKSPACE to move the carrier to the center of the typewriter, then turn off the typewriter and unplug the unit from the AC outlet.
2. Open the Top Cover and remove the cassette ribbon, if installed.
3. Pull off both spools by holding the correction tape taut between the spools; bring the correction tape to a position parallel with the platen and lift up and out.
4. Pass the new tape through left guide, behind the ribbon guide and out through the right guide. The rough (sticky) side of the tape should face the platen.
5. Attach the feeder spool to the pin on the left.
6. Attach the take up spool to the pin on the right. Turn the take up spool counter-clockwise until a small amount of white tape has wound around it.
7. Replace the cassette ribbon and close the top cover, plug in the AC cord to the AC outlet, and turn on the typewriter.
May 20, 2013 | Brother GX-6750 Typewriter
My Swintec 7040 when I type a letter or word only write a half of the letter or the word and when I try to erase a letter or word the typewriter erase this but the erase ribbon stay in the same position...
There are a few possibilities. If only the tops are printing Press down on the platen to be sure it is fully seated in the side frame. The T/W may be in the overstrike ribbon mode Code period, comma or slash will get you out of that mode.
DickyO
Oct 11, 2011 | Swintec 7040 Typewriter
My typewriter prints the bottom half of the letter. Do I need a new wheel or a defective ribbon. This started when I changed the ribbon.
Most likely the ribbon isn't in right. Go to NADIST.COM click on current models you will find a manual there.
DickyO
Jul 26, 2011 | Nakajima AE-740 Typewriter
Wheelwriter 30 series II. was typing OK but now get only less than half of letter to print. replaced ribbon same thing. tried adjusted ribbon (now sure was in right area) and still only printing less...
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
May 21, 2011 | IBM Wheelwriter 30 Typewriter
Typewriter not working
Look at the ribbon. If only the top half is beig printed on then the ribbon lift is out of adjustment or the ribbon is in wrong
Apr 21, 2009 | Royal Office Equipment & Supplies
Keystroke on prints top half of letter
Most likely the platen is not fully seated press firmly on buth ends of the platen (black rubber roll) it should snap into place.
DickyO
Jan 29, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
