Question about GE Profile JTP18 Electric Single Oven
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
Our GE Profile JTP18 Single Electric Wall Oven (30") has been flashing "Door Lock" and the locking mechanism keeps engaging and disengaging, ever since we ran a Self Clean. We've had a repair man out who has replaced the entire control panel, the touch panel, and the locking mechanism. He just told me he was giving up and going to have another repair company take a look at it. The Control Panel will only respond to the Self Clean button, the Clear button, or one of the timers (Kitchen or Cook Timer seem to work), and the Oven Light. The door will open if you catch it while the lock is disengaged. Any help would be great. We've been w/o an oven for just over three weeks, and we have three growing kids to feed.
  • hummeltc Nov 09, 2008
    I baked cookies for approximately one hour. Turned oven off. then several hours later the flashing lock light keeps flashing - What can I do.????
  • Anonymous May 12, 2009
    flashing locking door, engaging and disengaging. annoying and nothing seems clear the problem.
Most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Posted on Mar 18, 2010
  • supajenn Jan 08, 2011
    Our door locked in the middle of cooking.. I googled for an answer and almost gave up until I came across this! Thankfully all we had to do was held the door jam switch for about 10 seconds and everything reset! YAY!
  • Lavandula L
    Lavandula L Oct 19, 2013
    Thank you so much!!!
GE PROFILE RANGE
If the oven is flashing "LOCKED DOOR" on the display. even though the door is open, the fix is easy and there is no need for repair.
Press and hold the oven light button on the left side of the oven door jam through the entire process.
Press the self clean button, then the start button.
Wait about fifteen seconds, then press the clear/off button.
release the oven light switch and you are back in business.
My heart goes out to those who paid for service or repaced parts.
Posted on Oct 12, 2011
    New Friend:
After self clean my oven Lock light was flashing the actual lock was engaging and disengaging non stop. try this it worked for me when none of the other things worked. Shut off the breaker. Open the control panel. Behind the auto lock mechanism there are two small circular things. One has two yellow wires going into it and the other has two blue wires going into it. pull the yellow wires and reverse them. Then pull the blue wires and reverse them. The turn the breaker back on. The lock stopped engaging and disengaging and the light went off. the oven is now workingOur GE Profile JTP18 keeps flashing
Posted on Feb 05, 2013
    New Friend:
This just happened to us out of the blue. The oven had been running and all of a sudden a beeping started and the "door lock" message started to flash.
I tried one of the simple solutions I found here. At the top right of the frame of the oven there is a black button (looks like a short peg or dowel). When the door is closed, that button is depressed. I read online to press that button for 10 seconds or so. I did that and I noticed that the door latch moved on its own. It shifted from its right-most position to its left-most position. When it came to rest, the error message went off and I could use the oven again.
Posted on Apr 09, 2013
  • Marilyn Steffensen
    Marilyn Steffensen Jan 11, 2018
    You are demi-gods of repair to me now. I did exactly what you said and it worked!!!!! Now I can cancel that repair service I scheduled. All Hail Google Search!!!!
  • 4 Answers
I had this problem on a JTP18 oven. I found that the door lock switch was showing that the door was locked when it was actually open. This is not the main door open / closed switch. This is the switch that shows if the door is locked or not.
The switch is open when the door is locked and the switch is closed (or should be closed) when the door is unlocked.
In my case the switch was open even though the door was not locked.
On my JTP18 oven, the switch was too the left of the door lock mechanism. To access the door lock mechanism I had to remove the control panel.
I forced the switch closed manually (using a cable tie) and the blinking locked light went away and the oven operated properly. Of course, the door lock switch must be replaced.
Posted on Jan 24, 2010
Amazing. I've searched across the web, and this "locked door" problem appears to be a DESIGN FLAW across the entire product line: if you run the self-cleaning cycle, it WILL trigger this problem and despite the suggestion of a wide range of "self-help" strategies, the only real solution is to pay for a service call (and then, it appears, paying for a new control unit and probably an additional service call to have it installed, and then more service calls if the same problem occurs). We have a JGB900BEF2BB GE Profile range, and of course we've run through all the self-help suggestions at geappliances.com and on a dozen other web sites like this one.
Posted on Aug 17, 2012
    New Friend:
I tried all this nonsense and none of it worked and then I pushed the metal latch hook that locks the door with my finger, which apparently moved it a few millimeters back to the unlocked position and the flashing lock on the display stopped. This means there is a sensor on the metal hook that tells what position it is in. If it is just barely off the unlocked position it think it's locked and flashes locked.
Posted on Sep 27, 2015
Had the same problem on a GE Profile JCB909 range. The solution was simple but it was a little more complicated to get at the locking mechanism. First I had to remove the glass range top. I followed the instructions on the wiring diagram that came with the range: Unplug, remove two screws at front, lift front and prop up a couple of inches, remove two connectors at back, lift off hinges, remove ground wire (green) near back of range top. Lift range top off and set aside. Remove metal piece at front, 6 screws. Now you can see the locking switch. I use a multi meter to check the switches. Okay. Then I plugged the range back in, pushed in the black oven door open swithc on the left side. The locking mechanism cycled but the unlocked switch did not change state. It wasn't pushed in quite far enough. I simply bent the bracket holding the motor and the switches up a 1/32" on the switch side. That fixed the problem! The switch works. The flashing LOCKED is off. 15 minutes later the whole thing is back together. Repair time: 1 hour. Repair cost $0.00.
Posted on Feb 07, 2011
  • ED WHEELER Jun 30, 2012
    All you have to do is flip the circuit breaker off then on and it resets. You can also unplug the range. This happened to us after cleaning the oven.
It was a "reset" switch in behind the control panel that went off when the self clean cycle increased the temperature in the area behind the control panel got too hot. After flipping the breaker, and then flipping it back on the oven finally unlocked. I pulled the control panel off and pushed the reset switch. Everything fired back up great. I just won't use the Self-Clean ever again.
Posted on Oct 23, 2007
  • GE Master
  • 4,655 Answers
SOURCE:
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
After doing a self clean, the panel now flashes locked
thermal protector has caused lockout. happens w/ self clean a lot. it's a small thermostat device most likely on the rear of the oven. oven need to be pulled from wall to check/replace. you may have to open door w/a coat hanger if it's locked to get the door open to allow access to screws to allow removal of oven from wall if it's a built in. unplug it before doing anything. fuse is under back cover size of a bottle cap, 2 wires, should be "closed" normally. replace or spray w/freon to "reset" it.
May 25, 2009 | GE Profile 30" Built-In Single Electric...
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
How to self clean
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Our ge profile oven flashes door locked.
Check out my solution at the following link:
http://www.fixya.com/howto/h155060-dreaded_F7_error
I have now shared this with over 1470 folks and most report success.
I hope that it works for you too.
Dec 14, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
19,930 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
