Question about Midas Interactive Golden Age of Racing for Windows
Failure to load CD and continues to run forever
Golden Age of Racing clicking on Icon then requires the CD to be inserted,following insertion the CD runs but does not load.The CD will then continue to run unless stopped manually. Other CDs load OK??
    President:
  • 2,004 Answers
The lens has gone bad. Get a replacement lens.
Good luck
Posted on Apr 15, 2009
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Pop up comes up to insert correct CD when click on the icon to start the game
Did the game come with multiple CDs? Do you have more than one CD Drive on your computer? If so, try putting the CD in the other drive, and try the other CDs it came with.
Jun 12, 2011 | Ford Racing 3 - for PC
I had Studio 9 on my old computer(2004). I have purchased a new computer and I cannot install. It asks me for administrator clearance and it says it's not compatable. How do I install?
You must be using Vista or Windows 7 and also trying to insert the CD in the drive and initiating installation. Please try the following steps.
1. Check if you logging in as an administrator (if you have only one user account - forget it)
2. Insert the CD / DVD which has studio 9 and if any window automatically opens up close it.
3. Click on Start and click on Computer - then right click on the CD / DVD icon and click on explore, now you should be seeing a file named Setup / Install - Right click on the file and click on run as administrator and continue your installation process.
Mar 06, 2011 | Pinnacle Studio Version 9 for PC
Purchased a new ThinkCenter desktop computer and my Logitech X-230 speakeers will not work with it. Help! Ken
Probably your problem is your PC audio device not your new speakers.
First verify you see a small sound icon sound3.gif or sound.jpg in the Systray (generally at the bottom right hand corner of your screen). If this icon is missing follow the below section.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Also looks like there are some corrupt system files on the computer I would suggest that you run SFC scan which would scan for corrupt system files on the computer and replace them.
Steps to perform SFC scan:
1. Click the Start button
2. From the Start Menu, Click All programs followed by Accessories
3. In the Accessories menu, Right Click on the Command Prompt option
4. From the drop down menu that appears, Click on the 'Run as administrator' option
5. If you have the User Account Control (UAC) enabled you will be asked for authorization prior to the command prompt opening. You may simply need to press the Continue button if you are the administrator or insert the administrator password etc.
6. In the Command Prompt window, type: sfc /scannow and then press Enter
7. A message will appear stating that 'the system scan will begin'
8. Be patient because the scan may take some time
9. If any files require replacing SFC will replace them. You may be asked to insert your Vista DVD for this process to continue
10. If everything is okay you should, after the scan, see the following message "Windows resource protection did not find any integrity violations"
11. After the scan has completed, Close the command prompt window restart the computer and check.
The scan may take some time, so be patient. Windows will repair any corrupted or missing files that it finds. If information from the installation CD is needed to repair the problem, you may be prompted to insert your Windows Vista / 7 installation disk.
Dec 01, 2010 | Logitech X-230 Computer Speakers
How can install dreamweaver
Insert the Dreamweaver CD into your CD-ROM drive.
Do one of the following:
Macintosh: double click on the installer icon.
Windows: the installer should auto-run. If it does not, go to your CD-ROM in your Windows explorer and double click on the "autorun" file.
Enter the required information, including any registration codes required.
Windows users may be required to restart their computer.
What You Need:
Dreamweaver or Studio CD
or you can see the tutorial here:-http://www.siteground.com/tutorials/dreamweaver/
Nov 12, 2010 | Computers & Internet
HP5600 print cartridge- error- message
http://cluetechnologies.com/index.php?topic=688.0
Insert the correct CD
Windows Users:
a Insert the gray HP All-in-
One Macintosh CD.
b Continue to the next page.
a Insert the green HP All-in-One
Windows CD.
b Follow the onscreen
software.
c On the Connection Type
screen, make sure to select
directly to this computer .
Note : If the startup screen does not appear after you
insert the CD, double-click My Computer , doubleclick
the CD-ROM icon, and then double-click
setup.exe .
Jul 01, 2010 | HP Officejet 5610 All-In-One InkJet...
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
I need a sound card for my computer...But i can only down load it on my freinds computer...Can I do that? I can't down load it with my computer couse my modem doesn't work couse of the sound card...
I don't think you are talking about a sound card. You may be talking about a driver. If you are talking about a driver then when dowloaded on your friends computer you could transfere it to yours via usb flash drive or even cd with the driver on it.
Oct 24, 2009 | Dell Dimension 3000 PC Desktop
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
Wireeless
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Feb 12, 2008 | NetGear Wireless
Midas Interactive Golden Age of Racing for Windows Logo
64 people viewed this question
Top Midas Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Midas Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
