Question about Panasonic CT-32SL13 32" TV
Panasonic ct-32sl13g blowing fuse by power supply
125v fuse blows each time I turn tv on. It tries to start then blows and fuse turns brown inside. My question is, I used a 3amp 125v fuse when I believe it calls for 2.7amp 125v fuse, could the amps of the fuse used affect whether or not the t.v is blowing it. Appreciate any insight, thanks.
  • 7 Answers
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Posted on Jun 18, 2009
I have a Panasonic CT-32SL13 32 inch tv. Last week I turned it on and saw a small flash right by the power cord. I was thinking about getting a new tv and decided to see if it was something easy to fix. I found the easy fix right here on fixya.com. I took the back of my tv off and I saw the small fuse right by the power cord had blown. I went to Radio Shack, paid $3.20 for four new fuses, came home, replaced the fuse and my tv is fixed. Yay!!!
Posted on May 26, 2010
  • Dale Kennedy Sep 06, 2013
    does this tv have a reset button any place? I can not see a break in the fuse.
SOURCE:
I went to Radio Shack to buy my open 6.3 slow-blow
Yes you can try it,Go to this website Mats Electronics they list all kinds of Parts/Supplies
1-800-628-1118
Apr 28, 2010 | Panasonic CT-36SX12 36" TV
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
TV NO POWER
internal fuse, small 2 amp slow blow, check both, some times white coated inside when blows turns brown in middle, voltage spike problem
Jul 25, 2008 | Samsung Televison & Video
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Keeps blowing fuse
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Mar 11, 2008 | Panasonic CT-32HL43 32" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Won't turn on
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
T.v won't turn on at all
The 6.3 Amp 125V fuse always blows on this TV after a while. replace with a 6.3Amp 250V fuse and it should do the trick unless something else is wrong. a 6.3 amp 125V is almost impossible to find so chances are if you find a 6.3 it will work. Tried a 6 Amp 125v at first and it blows after the first time you turn it on and off and then back on again. 250V seems to work well. Hope this works for anyone else with this TV. Beats having to move it to the trash because it is HEAVY.
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Panasonic CT-32SL13 32" TV Logo
794 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
