Question about Video Game Consoles & Games
Xbox 360 tray stuck half way open no power - Video Game Consoles & Games
Close the door and turn the power on
Posted on Apr 15, 2009
  • 63 Answers
SOURCE: xbox 360 starts up randomly, tray opens and closes spontenaously
Have you opened the Xbox and tried to fix something?
Posted on Nov 21, 2008
  • 21 Answers
SOURCE: xbox 360 disk tray is stuck
Go to this microsoft website http://support.microsoft.com/kb/906935 and something goes wrong send me a message
Posted on Mar 10, 2009
  • 34 Answers
SOURCE: I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Posted on Jun 23, 2009
XboxRepKit
  • 168 Answers
SOURCE: my xbox 360 keeps saying open tray instead of playing my disk
This is more than likely your laser that is dead and its possibly a samsung or hitatchi drive, be careful when
buying a new laser because there is a lot of dodgy ones around at the minute which can damage your machine or
at the very least will be inferior and not last long.
its very possible it could also be your logic board which is a controller that controlls your dvd drive and laser etc. if this is faulty (and im betting its a samsung) then you might have to replace. you can pick these up for swap with the one on your drive for around £10 and can be effective but i would also checj the drive belt and make sure that is tight and working ok and tha laser too.
if your 360 reads dvd's but not games it may be repairable but if it wont read anything then your better off replacing the laser. strip down the console and strip the dvd drive, take out the laser and look underneath it, it will have a code such as HD57 or something else, note that down. Visit ebay and search for the laser with the same code, buy it, fit it in and make sure you de-solder the static blob of solder before using it (search the net about this or ask the seller) and then try your machine again :)
linda
Posted on Sep 28, 2009
Testimonial: "thanks i'll try it out"
  • 51 Answers
SOURCE: XBox 360 won't play discs. It just says open tray.
Your DVD drive's laser is malfunctioning.
You have a few options:
1) Decrease the resistance on the laser to increase power, and it may be able to read the discs again. A guide for that can be found here.
2) If that doesn't work, or you do not wish to do that, you can replace the laser head all together. Replacements can be found on eBay. You can follow this guide to replace the laser head.
3) You can replace the DVD drive completely, but it will require taking the original drive's firmware and putting it on the replacement one. The guide for that can be found here.
Posted on Dec 14, 2009
Tray stuck open
The gears on the Xbox 360 have become misaligned. Here is how you fix it. If the tray is out all the way disconnect the power.
Step 1:
Locate the tab on the left side of the tray.
Step 2:
Lift the tab with a pen or equal and pull the tray out.
Step 3: power on the Xbox 360 and hit the eject button. When you here the eject "ding" pull the power. Now the drive is in eject mode and the cogs are aligned to take the tray.
Step 4
Gently place the tray back in and slight nudge to engage gears.
Step 5
POwer on xbox 360 and give another nudge to help the tray realign.
Step 6
Open and close the tray a couple times. To assure sucess.
Aug 20, 2014 | Microsoft Xbox Video Game Consoles & Games
Tip
Xbox 360 - Stuck or sticking tray fix!
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on May 13, 2010 | Video Game Consoles & Games
Game stuck in the back of my xbox 360
If you have a xbox 360 the DVD drive is self contained you wil have to open the system to retrieve the game go to www.llama.com to find a tutorial on how to open the system
Feb 14, 2013 | Microsoft Xbox 360 Console
Tray on xbox 369 won't go back in
Your drive is stuck. You need to get it repaired. Or you can open it up and try it yourself. It probably just needs to be lined up with the opening better.
Jan 10, 2010 | Microsoft Xbox 360 Console
My xbox 360 disc tray wont open how do i fix that problem
Slap the top of the the box as you press eject. that will get it open.
then wipe a little rubbing alcohol on the black belt
just under the tray . And a little petroleum jell in the
tracks under the tray . Then open and close the tray to
work it in.
Rob
Sep 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 disk tray is stuck
Mar 09, 2009 | Microsoft Xbox 360 Console
Disc tray will not close
Unplug your 360 from the main power source and make sure there's is nothing that may be preventing the tray from closing completly
Nov 02, 2008 | Microsoft Xbox 360 Console
My son dropped the x-box 360
open the case and check to make sure the small drive motor (especially the small electrical wires) and belts are intact and operate smoothly for the feeder tray.
May 14, 2008 | Microsoft Xbox 360 Console
Disc tray stuck closed
Is it making the noise like it will open then getting stuck? If so, this can be tricky! It happens with me sometimes. Press the open button and as it goes to try and open push the disc tray in slightly and up and it should pop open, it does with me anyway.
Oct 22, 2007 | Microsoft Xbox 360 Console
Xbox 360 tray
I had the same problem after a while my xbox caught the red light disease
Sep 15, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
444 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
