Question about HP Compaq Presario R4000 Notebook
Dark screen if unhooked from battery
When we lose power and the Compaq R4000 is used again the screen brightness is very dim for 3-4 days. Is there a button on the keyboard to make it brighter again. I do not dare to unhook it from the battery because if I do it is too dark to work.
  • 748 Answers
You can use the function keys to increase the brightness. Also if you go to Start, Control Panel, Power Options you can change the settings to give you more monitor time.
Posted on Apr 15, 2009
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
HP Compaq Presario R4000 (PN495AV) PC Notebook How
Yes, go to Start>Control panel>Power Options. There also should be a screen brightness key on your key board, that looks like a sun shining, with arrows pointing up & down. To use that key, hit the FN key, right next to the Ctrl key. Push & hold the FN key, while pushing the up arrow. That should increase the brightness of your display. Good luck.
Jul 06, 2011 | HP Compaq Presario R4000 Notebook
Where is the contrast and brightness button and how do you use it? My monitor is too dark hp nc6120
Just go to power options in control panel and click change plan settings of you current plan and move the slider right to increase brightness.Please note the left slider is for when on battery while the right slider is for when connected to AC power. Finished.I hope it helps
Dec 11, 2010 | HP Compaq nc6120 Notebook
I install a screen screen for compaq r4000 bout it not showing the display bright
you may need to set your backlight settings. it could be done under power settings in your operating system or you may do it manually by pressing fn + up arrow key (or down arrow key).
also make sure you have the latest driver for your computer!
Mar 31, 2010 | HP Compaq Presario R4000 Notebook
My compaq r4000 is powring on but nothing is coming up on the screen
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Compaq Presario R4000 Notebook
Compaq r4000 dark screen
press F5 in the keyboard the light should be back or check the keyboard in the computer in the top botton where you see a sun design press that one you shoul have two of those 1 for put the light dark and the other one for put the light back good luck
Oct 13, 2009 | HP Compaq Presario R4000 Notebook
Compaq Presario R 4000 to dark when on battery only.
The R4000, or at least mine will appear to be brighter when on battery also. If you press the function key and then the f8 key it will brighten the screen.
Feb 24, 2009 | HP Compaq Presario R4000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Power Brightness dims after using Kinoma Player
Ok i think i can help,
Step 1: Go to preferences
Step 2: Go to power
Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
Masalama
Sheeraz Khan
Jan 02, 2008 | Palm Treo 755p Smartphone
Computers & Internet Logo
90 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
