Question about Kenmore 22085 Bagged Canister Vacuum
Kenmore vac producing burning odor
Kenmore canister vacuum #27515: Slight burning odor or "electrical arc-ing" odor when operated. Someone at store said that maybe the belt needs to be replaced. But isn't the "belt" only a part of the rotating-brush floor attachment? The odor is coming from the main unit, not that part. Unit is only a year old and hasn't had heavy usage.
  • 61 Answers
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Posted on Apr 15, 2009
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
I have a 2100 Electrolux cannister vac. I have just noticed an odd odor (similar to burning) and the protection mode light went on. Can you advise of steps to take to rtrouble shoot and what might be...
The motor is probably burning out, or has. Smell the exhaust port. If the odor is especially strong, here, then that's the problem. You'll need to take the vacuum to the nearest Aerus Electrolux store for definite diagnosis and repair/replacement of parts.
http://www.aerushome.com/storelocator/index.cfm
Feb 01, 2011 | Electrolux UltraLux 2000 Bagged Canister...
My kenmore cannister vac (model 116.27514) has a slight burning odor after operating for a few minutes. We have removed the hepa filter and it looks like there is a strip of foam curled up behind the hepa...
The foam you see is probably there as a noise suppressor. It shouldn't be curled up but age and heat
can do that. If the odor is an electrical smell that may mean the motor is going bad.
Jan 30, 2018 | Vacuums
Hi, I have a canister Kenmore vacuum with power head. Everytime I use it, it smells sour. Its strong and like FEET with bad odor. My old Kenmore did the same thing but I used it anyway...because the power...
Never heard of this odor but if you have had it in both vacs it might have something to do with a disintegrating rubber backing on a carpet.
Arm and Hammer makes a baking soda based vac powder that will help eliminate some odors.
Do several things , get the powder and pour a tablespoon of it or baking soda into a fresh bag. Keep your filters fresh. If you use washable filters be certain they are thoroughly dry before reinstalling. And use a Mutli ply filter bag.. and NEVER pick up anything wet or vacuum a damp carpet
Sep 10, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Rollers not spining on my kenmore canister vac.
Particles of the failed belt may be  trapped in the bearings which, if I remember right, aren't very well protected.
I'd remove the rollers, slide the bearings off (if they do slide off) and blow them out with a compressor or saturate them with WD-40 and turn manually until they are free again.
Jan 15, 2009 | Kenmore 22313 Bagged Canister Vacuum
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Druabrand canister vac
I was looking for a Hose for the vac, and found one at good will store that will work. Others wanted more for the hose than the vac was worth.
Nov 05, 2008 | Kenmore 22612 Bagged Canister Vacuum
Burning Smell coming from the moter
This could be a motor problem. There is always a slight blue arcing that occurs when an electrical motor runs and can be visible through the exhaust vent, but any excessive arcing indicates a problem. If the carbon brushes are sticking, this will cause excessive arcing and can be corrected by an experience service person, but if there is any electrical failure, the motor would have to be replaced. There are no parts available for these motors and the expense of replacing an armature (the likely culprit) would be more than the motor. This could also be as simple as a worn belt, but usually, belts will not produce the smell your describing. When a motor is burning out, it will produce an acrid odor that will linger for a long time.
Feb 23, 2008 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Kenmore 22085 Bagged Canister Vacuum Logo
318 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
