Question about MSI K8N Neo4-F Motherboard
On startup fans only run a second then stop
I've unplugged graphics card, memory, drives, etc, and the result is the same so the problem is the MB. Is there any further debug I can do or is it time to ship it off to MSI for out-of-warrenty repair?
  • 3 more comments
  • bongos292 Apr 16, 2009
    Perhaps my failure mode description was too brief. The fans stop, all lights go out, and it doesn't boot. I believe the PS has detected a short, probably in the MB, and has shut down.
  • bongos292 Apr 18, 2009
    To test power supply I followed the procedure at:
    http://www.techwarelabs.com/guides/misc_...
    It indicated the PS was OK.
  • Anonymous Apr 30, 2009
    I have the same problem. I believ the MB shorts out. It just shuts of and then acts like it's in hibernation however you can get it to stop flashing unless you turn off the power supply. It did this for a bout a week. Now only the fans run but the OS doesn't turn on.
  • kurtisckelle May 02, 2009
    Same problem here. Fans run for a second on startup and then the system shuts down. If I try to start again, nothing happens at all. After a few minutes, something resets and I go through the same senario; press start, a second of fans running, then shut-down. This used to happen occasionally and now is constant, so I cannot boot up the computer. Power supply and power switch checked out okay on the bench.
  • Dick
    Dick May 11, 2010
    Repair is not cost effective, replacement is the way to go. It would cost more to repair the board than purchasing another board, processor, and memory.
  • 661 Answers
I think this is fairly normal, most modern motherboards use thermistors to check the system temperature, (which windows then overrides) so on startup your fans will test for about a second and then turn off until the thermistor tells it the system is getting too hot ( I think this is called Acoustic management)
you should be able to bypass this in BIOS if you want, but as your system gets to windows those fans should kick in..
Posted on Apr 15, 2009
  • Gareth Cockram
    Gareth Cockram Apr 16, 2009
    This sounds like a faulty Power supply, I've had this on my own PC and replacing the Power supply did the trick for me
No picture video card is on tho
Update your Graphic card driver, also cool your card with an external fan etc. Overheating can result in this certain issue!
Jan 26, 2012 | Jaton 3DForce 3450DVI Graphics adapter...
Just wanted to no if this graphics card was any good thanx kris
these cards have not been reviewed as far as i no but they do read well
Graphic Processor: NVIDIA GeForce2 MX Installed Memory / Technology: 32 MB (SDRAM) Card Interface: AGP 4x Compatibility: PC Memory Installed Memory: 32 MB Memory Tech: SDRAM Memory Data Width: 256-bit Technical Features Form Factor: Plug-in card Max. Screen Resolution: 2048 x 1536 Miscellaneous Product ID: 20258597
GeForce2 MX brings the power of NVIDIA's second-generation graphics processing units (GPU) to desktop PCs and Apple Power Mac computers. The result - the same stunning visual experience PC users expect from NVIDIA GPUs. ??Leveraging the second-generation architecture of the GeForce2 GTS, GeForce2 MX is a robust GPU at mainstream price points. GeForce2 MX uniquely incorporates Digital Vibrance Control (DVC), which makes all images - including 2D, 3D, and video - brighter and crisper, even on digital flat panels, with the flexibility of the TwinView dual-display architecture.
hope this helps you
Aug 19, 2011 | Leadtek WinFast GeForce2 MX-MX64 (32 MB)...
I dont know much about graphics cards but I know I have all the requirements. I play Call of Duty World at War, but for some reason after ten minutes of playing the screen freezes, changes color and makes...
The issue is the card is overheating you can take the card out and ensure that its clean and if nothing seems to work you will have to replace the card this is a common issue with this card. Most of the time you can remove the fan cover on the video card and clean the dust out of it and it will work.
Dec 01, 2010 | Computers & Internet
Video card....
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Feb 07, 2010 | Toshiba Satellite Laptop
I deleted a file from my USB stick and now cannot relocate it as it was the wrong file. Where can I find the file to restore it? It is not in the recycle bin?
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jaz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives , Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Download and install from here: http://www.filehippo.com/download_recuva/
Jan 14, 2010 | Kingston flash memory card - 256 MB -...
MB starts up, CPU fan runs, after 5 seconds, one beep and MB off
It appears that the system is shutting down without you telling it to.
If it does this at a given time interval, the problem is most likely heat.
Can you boot the system with a start-up disk (a system disk) and have it keep running?
Your heat problem can be in the CPU or in the power supply. Have you checked the power supply fan to see if it's running?
Have you removed the heat sink and reapplied a good thermal grease?
Aug 10, 2009 | AOpen MX46-533V (91.89U10.061) Motherboard
Cannot install manufacturer driver
does the card support 64 bit windows ? their are a lot of issue using 64 bit windows
Mar 24, 2009 | Chaintech XGI Volari V3, (128 MB) Graphic...
Mb 865
few things to try -
unplug the cd-rom's + hardrives (your pc will boot without these, at least to your bios)
try 1 piece of memory if your using 2 or more (might have to try all seperatly incase 1 is faulty)
if you have onboard graphics remove the graphics card
make sure your power to the board is pluged in (some motherboards require a 4 pin power aswell)
try these and let me know how you get on, we can take it from there
Feb 09, 2009 | HP dx2250 Monitor Personal computer AMD...
Can't get my dual graphics cards to work
1. Turn all of your 3D settings to 4x.
2. Go to BIOS and turn your AGP aperture size to 256 MB
3. Increase the virtual memory size to the double of the physical system memory (set it to 1024 MB in case of 512 MB system memory, Control Panel \ System \ Advanced \ Performance - Settings \ Advanced \ Virtual Memory - Change, select the hard drive, choose Custom, and enter into both fields 1024, then Set, OK and reboot)
4. Lower the hardware acceleration in Windows with one stop (Control Panel \ Display \ Settings \ Advanced \ Troubleshoot \ Hardware Acceleration).
If you still not be able to fix it, I suggest you to go to this site http://www.foxpop.com/imre/2005/vpurecover/vpurecover.html
Yuo might want to use ATI's driver too.
Nov 19, 2008 | VisionTek RADEON HD 3870 X2 Video Card -...
CPU does not start
Hi, have you tried removing all the cards (video, lan etc) and all power connectors to drives? Run only your mb. If problem persists then it is possible that there is a short in the mb since the psu auto protects and shutoff. You can also try removing the retaining screws of the mb and try running it completely off the back panel. Care should be taken to ensure that the back of the mb does not touch any metal part of the casing. You can try sliding in between a plastic folder or something. If psu still shuts off, then you it is most likely the mb is fried. Please let me know if this works out for you. Regards
Apr 09, 2007 | Intel D865GLC Motherboard
MSI K8N Neo4-F Motherboard Logo
340 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
