Question about HP Officejet Pro L7680 All-In-One Printer
Software loads but HP solution center won't open
Had computer reimaged, software reloaded. Stalls at 96% for @ 10 min then completes without any info. Printer works but no fax or scanner. Desktop shortcut and direct link to HP solution center will not open program. Error message states that no HP product has been detected and HP Solution center will shut down. All software appears to be installed but some interface seems to be missing which won't launch the program to access the fax and scan modes.
  • 2 more comments
  • eyi0 Apr 15, 2009
    Its not a USB connection problem. The OS is Windows XP Pro Ver 2002 Service Pk 3
  • mytmo May 03, 2009
    I have the exact same problem - Have contacted HP support and they gave me 4 different ways to install un and reinstall - nothing works - took the PC to Best buy and they can't figure it out or fix it - can anyone help me ..........please
  • Anonymous May 13, 2009
    I have the same problem, and the same operating system, service pack, etc.
  • buffalonyman
    buffalonyman May 11, 2010
    Is this USB connection?
    What Operating System?
    Problem Solver:
  • 12 Answers
I would recommend un installing "any" HP software first, then download and install the latest driver from HPs site. You could could also try running the installer with all startup apps disabled incase there is some conflicting software. You can do this by typing in "msconfig" from start > run. Once open select "selective startup" then uncheck "load startup items". If you resort to this be sure you have unintstalled all HP software first as some HP software does run at startup. Also be sure to re-enable the startup items after troubleshooting.
Posted on Apr 15, 2009
Loading drmk v8.00 is shown when F8 is pressed before booting
This sounds like a resealing issue. Was this computer reimaged recently? If it were, I would simply reimage again...it looks like the job didin't finish completely.
Nov 23, 2012 | Computers & Internet
How do i uninstall k9 web protection without a password?
I do not think you can unless you get the password or reload the computer clean/reimage the system.
Jun 30, 2011 | Blue Coat Systems K9 Web Protection
My 02 Camry v6' battery was removed for 30 min and put back on - good battery. Engine starts no problem but stalls at idle. No error code. Is a computer-code reload or IAC cleaning ? Seems the car computer...
idle learn procedure:
turn off all electrical items (AC fan, audio, lights, defogger, etc.)
Start the engine and hold it at 3,000 rpm with no load (in park or Neutral) until the radiator fan comes on or the engine coolant gauge shows normal running temp.
Now let the engine idle for a minimum of 5 mins with no electrical loads. If the radiator fan cycles on during this time, you must add the fan running time to the 5 mins.
Feb 10, 2011 | 2000 Toyota Camry Solara
Just got windows 7 on my laptop and had to reinstall the printer software for my hp photosmart C5180 my disk were not compatible so I installed the software for the hp website .it will print and scan but i...
Follow these steps for the Windows 7 operating system.
NOTE: HP introduced HP Solution Center to replace HP Director in 2005. HP Director is not compatible with Windows 7. If you were using HP Director with your printer and then upgraded to Windows 7, the information in this section can help you. hpweb_1-2_plus.gifhpweb_1-2_minus.gifDo I have HP Solution Center on my computer? HP Solution Center is part of a full-feature installation of the printer software. It does not install with a Basic driver installation. Also, you might have excluded the program if you performed a custom installation. Check whether HP Solution Center displays in the list of installed programs: On the Windows taskbar, click the Windows icon (c01319360.gif ), click All Programs , and then click the HP folder. hpweb_1-2_plus.gifhpweb_1-2_minus.gif HP Solution Center icon is blue (c01810967.gif ). If the HP Solution Center icon is blue, you have an older version of HP Solution Center. Go to the following "How do I get HP Solution Center?" section in this document to download the latest version.
To scan a document using Windows Fax and Scan in Windows7, follow these steps:
  1. Click the Windows icon (c01319360.gif ), click All Programs , and then click Windows Fax and Scan .
  2. Click New Scan .
  3. Make any desired setting changes, and then click Scan .
Get the full printer driver:
HP offers the most current software available for your printer as a free download. HP Solution Center is part of the Full Feature Software and Drivers download. Follow these steps to check whether this option is available for your printer, download it, and then reinstall the software and drivers.
  1. Disconnect the USB cable from both the product and the computer (if you already connected it).
  2. Turn the product on.
  3. Open a new window to browse to the Get Software and Drivers page: Right-click this link, Get Software and Drivers , and then click Open in New Window .
  4. If prompted, type your product number, and then click Next . You might also need to click your model in a list of similar products.
  5. Select your operating system, and then click Next .
  6. Click the Plus sign (c02200813.gif ) next to Driver , and then click the driver that you want to download. If you need help deciding, see the information in the previous table.
  7. Click More Info , and then read through the minimum system requirements and additional instructions. You can also click View directions (c01647276.gif ) for complete download instructions.
  8. Click Download . This option allows you to install the software at any time after the download completes.
  9. Click Save , and then browse to the location on your computer where you want to save the file.
  10. Click Save . The software downloads to your computer. Hint: Make a note of the place that you saved the file, in case you want to install it at a later time.
  11. Browse to where you saved the file, and then double-click the file to start the installation.
  12. Follow the on-screen instructions to complete the installation.
Nov 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have a Photosmart M425 digital camera. When purchased, I downloaded the software to my computer. Since that time, my computer has crashed and been replaced. I cannot locate my software. Is there a...
You can download the installation driver and software from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu and click the "Next" button. Then download the required drivers and software.
The list of available software will load only after selecting the operating system of the computer.
Click on the "+" sign next to the list to expand the list and view details. To read the detailed installation instruction, click on "More info" link under each driver/software.
You can also order a replacement installation disk on the page which opens.
Hope this solves your problem. Thanks for using FixYa.
Sep 14, 2010 | HP Photosmart M425 Digital Camera
When turning Buck Hunter Pro on i am getting an error message error 0x01 Loading Linux - 2.6.12-bs thei text keeps repeating on the screen.
You most probably have a hard drive problem, corrupt software or less likely a motherboard problem. First step is to reimage the hard drive. You need an install disk to do this. If one isn't present you can obtain one from a distributor such as Betson in the US or Brent Electronic in the UK. After turning the machine on open the coin door and press the DVD button on the computer to open the DVD drive's door. Insert the disk and close the door. Turn the power off then back on again. The software will now install, and follow any instructions. If the game doesn't run properly you will need specialist help. I would suggest sending the core computer to a distributor or specialist dealer for testing and repair.
Jun 06, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
HP C7180 photosmart Scan problem
first: the C7180 will only work in ONE mode: wireless or wired. End of story there.
second: I spent almost 4 hours, yesterday, fixing this problem - "would not scan to computer because printer did not recognize computer for scanning yet would print & copy ok". I did solve the problem! Here is what I did: 1) removed all software related to C7180 ( make sure it is all gone ). 2) turned off all firewalls & security measures to ensure a clean, uninterrupted reinstall ( be sure internet connection is off for this to be safe ). 3) reloaded software ( hopefully you have the cd for this ). 4) followed all prompts for reload of software & then rebooted computer & tested copy mode, fax and finally scan. 5) went to HP site & made sure I had all updates & everything was ok with drivers. It was. I now have a clean install & all works as it should. The whole process ( after I figured out that it was a software problem ) took about 1 hour. Don't forget to reset your computer security! Be sure your firewall knows all HP software is good & firewall will let it thru.
This should do it.
Oct 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
Scanning Problem
first of all uninstall the software completely,reboot the system,install thesoftware n connect the the printer only when asked by the software
Jan 27, 2008 | HP LaserJet 3055 All-In-One Printer
Unaccessible Drive
I have seen this before and the result was becuase the encryption was activated on the device (a password set) and then the software was lost of the PC - in your case due to the reimaging. Manual installation of the software is required. It is available from: http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Aug 11, 2007 | Maxtor OneTouch III Mini Edition (R01E100)...
HP Officejet Pro L7680 All-In-One Printer Logo
2,395 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
