Question about Sharp AR-M205 Copier
Flashing L 6 error
L 6 code on copier
  • 2 more comments
  • dra3981 Apr 15, 2009
    Bob-Thanks,but the sequence did not clear the L6 code.
  • gig8 Apr 20, 2009
    Hi guys
    I've the same problem by switching on the AR-M205 the error code L6 starts flashing.
    Somebody know something about this problem, can it by fixed?
  • kkens Apr 25, 2009
    sir,
    i have a sharp AR-5320 copier machine and i want to reset main counter please any budy guide me in case of any requierment to any budy i will guide in xerox copier any problem
    thanking you
    kens
    my email id kalpesh30180@rediffmail.com
  • jschuett May 11, 2009
    I have the issue with the flashing L6-10 error code. My machine DOES have an intturrupt button on it. Bob, should i substitute that into the sequence you have provided?
    Thanks!
    Sniper:
  • 67 Answers
Press clear
press *
press #
press *
enter 14
press the start key
I may have the * and the # swapped, it has been a while since I worked on one.
please let me know if it work and if it did please rate my help
Thank you
Bob
Posted on Apr 15, 2009
  • hinderschied Apr 16, 2009
    L6 is an error code with aproblem in the laser unit. If you turn the machine off and then back on does it clear the code, then go back into it or does it have the L6 flashing as soon as it is turned on?
    I did have my buttons confused a little and did not find AR-M205 manual, but found some close to the same generation.
    Press #
    press *
    press clear
    press *
    enter in 14
    press the start key
    If this doesn't work let me know and if there is an interupt key on the control panel.
    Thanks and good luck
    Bob
All the buttons are non responsive and the copier flashes 40 U 2. I can't get it to clear or do anything.
U2 error code reset.
Go to simulation mode by pressing # * C * (press these four buttons as soon as possible) the display will go off, then enter 1 6 and press start key. The machine will restart automatically. However if the toner chip is defective, the error will not reset. Replace the toner chip if required.
Nov 30, 2012 | Sharp AR 163 Copier
I HAVE A CODE C-6 ON COPIER AFTER POWER WENT OUT
have a copystar#GS-1500 and after power went out, have flashing error code C-6 and 400. Worked perfect just prior. please help!
Oct 13, 2010 | Copystar CS-1500 Copier
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
    Armstrong
    FAILURE CODES
    LED Status Fault Description
    Off
    No Power to the System Control
    Steady Flash (11 or more flashes with no pause)
    Normal Operation (Standby or call for heat)
    2 Flashes
    Pressure Switch Closed When It Should Be Open
    3 Flashes
    Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
    4 Flashes
    Open Limit Switch or Limit Switch Circuit
    5 Flashes
    Flame Sense Signal Sensed Out of Proper Sequence
    6 Flashes - pause - 1 Flash (see Note 1)*
    Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
    6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
    Soft Lockout Type 2 (Flame sense lost during run)
    6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
    Soft Lockout Type 3 (Pressure switch opened during run)
    6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
    Soft Lockout Type 4 (Limit or limit circuit opened during run)
    6 Flashes - pause - 5 Flashes (see Note 1)*
    Soft Lockout Type 5 (Flame has gone away after Error Code 5)
    6 Flashes - pause - 7 Flashes (see Note 1)*
    Soft Lockout Type 7 (Self-check failure)
    10 Flashes* - SV9520H8034 only
    Line Input Voltage Polarity Reversed
    Dec 12, 2009 | Coleman Heating & Cooling
    Canon Pixma ip3000 flashing amber 6 times
    If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
    This code indicates the following;
    Internal temperature error [5400]
    The solution to this is the following part replacementl
    - Logic board ***'y (QM2-1548) *1
    *1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
    more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
    logic board ***'y.
    [See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
    Good luck!!!
    Jan 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
    I had the error message L-4 .can you halp to fix this problem?
    L6 is a laser polygon motor fault, you need to replace the polygon motor in the laser unit, but try the reset code first sim 14
    May 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
    FLASHING ERROR 6 L
    L6:The Main PWB sensed a Polygon motor lock signal error. 5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module. What that normally means is the laser mirror motor has failed. That normal price for that item is normally over $300. Here is a parts dealer to contact to see if they have it in stock. https://www.partsdrop.com/store/
    May 15, 2008 | Xerox WorkCentre XD120F Laser Printer
    Flashing error code
    Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
    1. Find the pink Clear button on the Control Panel of the WorkCentre.
    2. Find the button below the word Auto.
    3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
    4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
    5. Press the green [Start] button.
    6. Press the pink [Clear] button two times.
    7. The WorkCentre should now warm up and come to ready.
    8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
    Dec 20, 2007 | Toshiba e-Studio120 Copier
    Sharp AR-M205 Copier Logo
    449 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    CheckitRight
    CheckitRight
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
