Question about Maytag PAV2300 Top Load Washer
Cold water trickles very slowly hot water has plenty of pressure it is a maytag pav2300 how can i fix this problem
    President:
  • 1,865 Answers
1. Check cold water hose for obstructions
2. Check cold water spigot for proper water volume
3. Cold water electronic valve may be failing, easy to replace
Posted on Apr 15, 2009
Cold water does not flow in at all
Make sure the cold water hose is turned on. You should have two hoses running to your machine.
Oct 06, 2012 | Maytag PAV2300 Top Load Washer
Silt, sand, something from deep water well has migrated past exterior washer hose screens into washing machine. Older Kenmore HD Series 70 top loading washer. How to fix?
probable but unlikely
the control valve for the water ( hot or cold ) has a diaphragm in the main flow with a small hole in it to act like a pressure regulator
so when the solenoid shuts off the water , water flows through that small hole and locks the diaphragm firmly on the seat
I suggest that the low flow is because that diaphragm has been compromised and is not opening correctly for full water flow
take it apart and clean it out or replace it
Feb 04, 2018 | Kenmore Washing Machines
I have a two speed heavy duty large capacity washing machine that I bought 20 years ago (model A8420). It works very well except that the cold water only trickles in as if there were no water pressure....
(this is pre-typed so just read 'cold'!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 30, 2011 | Maytag Washing Machines
Our PAV2300 has a problem filling. When I set it
I can tell you its not in the hoses, typically in the washer where the hoses go in there will be a screen. Check these screens, you will get a lot of sediment built up on these, i have to clean up mine every 2 years. This will still have to be done even if there is a water softener. If this is not the problem then I suggest checking every valve in the cold water system. Making sure they are opening fully.
Jun 24, 2010 | Maytag PAV2300 Top Load Washer
The cold water just started to barely trickle on all cycles .... i checked the line going in to see if it had one of those mesh filters and it does not. how do i troubleshoot this?
You also want to check at the back of the machine where the hose connects. Some machines have a small screen inside the threaded portion of the valve that may trap debris. Be sure to check both ends of your cold water hose for screens also and be sure to run the cold water full blast through the hose directly into the washer before re-installing the screen (if there is one) to lift and eject any other heavy particles that may be floating around in the cold water supply. When doing this flush out method make sure the pressure is good and that you don't have a potential plumbing issue causing your troubles.
If none of these suggestions fit your next option is to replace the cold water valve.
Jun 16, 2010 | Maytag PAV2300 Top Load Washer
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
Possible Mixing valve Problem
I would pull the lines off the back and check the inlet filter on the hot and cold sides of the water inlet and clean the screen style filter. If you just use cold is the water cold if the cold water valve was bad then you would get no cold wate when set to cold.
Jan 20, 2010 | Maytag PAV2300 Top Load Washer
I think the cold-water solenoid went bad on my washer - plenty of hot water flow, but cold only trickles into the washer. The rest of the house is fine for water pressure.
yes the most likely problem is your water valve hasgone bad.but check the hose connection and see if there is any sediment built up in there. if not replace the water valve
Sep 27, 2009 | Washing Machines
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
112 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
