Question about 3Com OfficeConnect Wireless Router
Routers How do i reset my 3com router 3CRWE52196? please help
  • ma_year Nov 27, 2008
    hhhhhhhhhhhhhhh
The ip 192.168.1.1 do not answer on browser, not show any web for configure this, can i do ?
Posted on Jan 06, 2008
    President:
  • 2,961 Answers
Connect to the router using a lan cable, not wirless, then you need to type 192.168.1.1 in your browser and look in settings menu for factory reset. the orange light on your router will flash slowly, at this point you will need to remove the power cable for ten seconds, then replace. After that continue to set up your router
Posted on Sep 15, 2007
  • 154 Answers
Make sure the router is powered up. Locate the reset switch on the back of the unit (sometimes a very small hole labelled reset). Push a paperclip into the hole gently, you will hear or feel the switch engage. Hold it there for at least 30 seconds. start internet explorer (blue e) in the address bar type 192.168.1.1 and press enter the new screen, type in the password to enter the set up (as it says, admin is the default) click setup wizard, put a dot in pppoa (I'm assuming you're in the UK) click next, put in your user name and password, vpi/vcn 0 and 38 and encapsulation VC MUX, click next put channel to 11, choose an ssid (i leave mine at 3Com), click next, check all the data is correct then click on apply.Now to set up the encryption start internet explorer (blue e) in the address bar type 192.168.1.1 and press enter in the new screen, type in the password to enter the set jup (as it says, admin is the default) click wireless settings on the left hand side of the screen, click setup wizard select wpa-psk from the drop down box where it says pre-shared key, type in a MEMORABLE password and then click apply. Now you will lose your wireless signal. Panic ye not! Click on the smatt TV in the lower right hand side of the screen (this is called the sys-tray) you will now see that the wireless icon which looks a bit like a telly with 3 yellow arcs coming out of it's right hand side has a red cross on it. Click it once, click view wireless networks and then on the new screen click refresh network list. You will after a few seconds see your network -click on it and then on connect. A new box will come up asking you for the network key aka password. Enter the memorable password you have just forgotten in the upper and lower boxes and press enter. Et voila! you now have an encrypted wireless network and you can only get onto it if you know the memorable password!
Posted on Feb 13, 2009
SOURCE:
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
Reset
RESET WIRELESS ROUTER
If you cannot access the router with the default password,or even the one you created, then most routers will have a small button (hole)that will restore the router back to the default settings.Every manufacturer's router is different, so a user Manualwill often be required in locating the specific settings you need to change.Go to the 3Com WEB site for details on resetting your router.
Jul 22, 2012 | 3Com OfficeConnect Wireless Router
LOOKING for 3Com OfficeConnect Wireless Router password. the default password was "admin" but somehow it is change and eveen after Reset can't change it
hi normally after a reset the user name is normally, (admin), and the password is normally (password)....hope this helps
Apr 13, 2010 | 3Com OfficeConnect Wireless Router
3com 3crwdr100a-72 how do I reset the router
For 3com type of routers, you must connect firstly to 3com setup, By:
First: open your browser and type 192.168.1.1
Second: you will find adapter setting and reset it, it all depends upon your router's software.
Third: the easiest way is to reset it from the small button in the back of your router.
Dec 14, 2009 | 3Com Wireless LAN Access Point 7250...
3012 3com router
Just find the "reset" button that can be pressed by paperslip and this will reset router back to factory settings
Sep 14, 2009 | 3Com RTR 3012 Router (3c13612-us)
I CAN`T GET THE TUTORIAL NO GATEWAY ON ROUTER 3COM 3CRWER200-75
i am not sure of this, however try this link this might help
www.scribd.com/doc/3800821/3COM-3ComX-GreenBow-IPSec-VPN-software-Configuration - 375k
Mar 17, 2009 | 3Com OfficeConnect Wireless Router
3Com Wireless 3CRWE52196
If you lost your Internet user ID and password you need to call your Internet Service provider technical support number and follow the step-by-step instruction provided by the operator.
The procedure require interaction and information on your specific account, that is the reason why you need to call ISP.
If you do not know ISP number, post details your location and internet company (EG: I live in Mexico, I have AT & T internet), possibly on a new request on Fixya, as sometimes follow ups on old questions go unnoticed.
Sep 20, 2008 | 3Com OfficeConnect Wireless Router
3Com OfficeConnect Wireless Router Logo
633 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
