Question about Westinghouse LTV-19W3 19 in. LCD Television
'no signal input'
Suddenly TV went black, use of remote turned TV on with D-sub in righttop corner for 3 secs followed by 'no signal input' in center of screen lssting 5 secs
    Scholar:
  • 133 Answers
D-Sub is usually used for input from a computer, make sure the TV's input source is set to Analogue or Digital (or DTV) as it seems to be set to accept input from a computer, if you do not have a computer connected, then this is why it is complaining of no signal. It will not automatically defer to normal TV without being told to do so, have a look in the manual, or guess around the remote control to change the source of the signal.
Posted on Sep 17, 2007
SOURCE:
TV screen went black, sound is intact, can I fix it?
This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
Mar 02, 2015 | Televison & Video
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
Our HD input suddenly went out.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
May 25, 2017 | Mitsubishi VS-45605 50" Rear Projection...
I had nothing but problems with my plazma since I bought it. But a couple months ago there was too much red on the screen so I adjusted the red to almost 0 and it was OK not great picture. Then the other...
your main digital and sub digital have failed. incredibly expensive.
there is one attempt that you can make to try (by chance) to save it temporarily.
The digital and sub digital are the two boards in the center of the TV where the input jacks are located.
Carefully disassemble and remove the top layer board (sub digital)- it is connected to the board beneath (digital) by a multi pin connector about 2" in from the left hand side. This is where you problem is. Reseat that connector by removing the board then replacing it.
Apr 15, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have a 32 in HD Emerson for some reason last night I was watching a show on Direct TV when the TV went blank . I was instructed no signal so I followed the promptsand it got signal but all I have is a...
Georgine you should have a button on your EMERSON remote that says input or source.
Press that button and a menu should come up with a list of options
use the arrow keys in the center of the remote to highlight VIDEO
Press enter or the circle button in the very middle of the remote
Dec 03, 2010 | Emerson Televison & Video
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
I have a yamaha htr-5240 receiver. Also have a 6 speaker polk-audio surround set.Center,2 rear,2 front,& the subwoofer. The sub is a psw-250 with no sub out or LFE.I can't figure out what i've done...
First, look at the sub, their should be a switch for "auto" "off" "on" switch it to "on" Then use the Left input on the sub not the right. Left is for mono. Now, if you still dont have any sub, disconnect the RCA at the receiver and touch the end of the RCA, if the sub is on, you will hear a loud humm. Now, go back into the receivers Menu and go into manual setup, find "Audio" and select "Auto". That should do it. If not, put the receiver on "Tuner" and set the sound to 7 channel stereo (I'm not sure if the HTR series has this) or "Adventure" I'm a Yamaha RXV series Dealer so the names may differ. (check in manual for audio surround settings) Anyway, this should let you know if you've got all your spkrs working. Then make sure your TV's external audio is set to "Fixed" (it may be called audio out) depends on TV type. Scroll thru TV's audio menu. If you still have problems post a comment and I will help some more. Hope this helps
Jun 21, 2009 | Audio Players & Recorders
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
TV turning on and off
Air 2 is the source it's looking at for a signal - - where is the signal plugged into? and are you able to change the input or source to look at another?
Bill
Nov 29, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Westinghouse LTV-19W3 19 in. LCD Television Logo
1,386 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
