Question about Mitsubishi X200 Multimedia Projector
Mitsubishi lvp-x200 when i plug in my projector nothing comes on. I have 2 of these that i bought at an auction a couple of days ago, they dont have lamps in them, but i would think they should show some kind of power going through them wont they? I just dont want to buy a expensive bulb to find out that their is something more costly that i would have to buy. i have taken the one apart to look and see if there is anything that i could see that is wrong. it looks like the main circuit board has three or four layers, so it is pretty hard to trace wires around, but if i could find a service manual or a wiring diagram, it would really help. thanks
2 Suggested Answers
SOURCE:
  • 1139 Answers
SOURCE: Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 20, 2008
Why will my mitsubishi lvp x300 projector only project a blue screen when I turn it on?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal.
Sep 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Why will my mitsubishi lvp-x300 projector only project a solid, blue screen?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal..
Mitsubishi lvp-s290u turns on and works for about an hour then turns off
Give it a good cleaning while off with canned air. Be sure to clean filter if it has one. Do not spin the fans too fast or they will lock up.
Oct 16, 2012 | Mitsubishi Lvp-s290u Lcd Projector
Lamp timer reset
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the < > and POWER
buttons simultaneously.
Jan 16, 2009 | Mitsubishi LVP-S250 Multimedia Projector
Mitsubishi LVP-X30 Multimedia - No picture
yes its because of your bulb and filter in the projector clean the filter and see if that works if not your going to have to purchase a new bulb from the manfatures web site
Jan 04, 2008 | Mitsubishi LVP-X30 Multimedia Projector
Projector won't turn on
Have you checked the user manual to find out what this "error message" means?
You may need to replace the lamp.
Jan 03, 2008 | Mitsubishi LVP-X80U Multimedia Projector
LVP-X3004 Mitsubishi Projector
Problem could be a fan problem or heat sensor or power ballast. Or at a board level a circuit board component failure - IC, capacitor etc Best to have it serviced by an authorised repair shop for Mitsubishi projectors. Regards Kevin Andreassend http://www.iceav.co.nz [email protected]
Jun 22, 2007 | Mitsubishi LVP-X30 Multimedia Projector
Mitsubishi X200 Multimedia Projector Logo
82 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
