Question about NetGear WGT624 Wireless Router
I need the driver wgt624 v3 - NetGear WGT624 Wireless Router
    Guru:
  • 523 Answers
Dear Friend ,
                   For a Router u no need of any Driver so Kindly these setting in the System and the Laptop
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Enabling DMZ:
1. On the left side of the setup page, click on the WAN Setup under Advanced tab.
Regards,
Aysaam
Posted on May 05, 2009
    Genius:
  • 1,269 Answers
The router's doesn't require driver to work. It can be setup using the router's Admin page. Try to reset it first, make sure you have a broadband connection. Connection should be as follows
Modem > Internet port of router
Computer > port 1 of the router
Posted on Apr 15, 2009
2 Suggested Answers
  • 104 Answers
SOURCE: my WGT624 v3 has no power, seems dead
Yup, I have seen those die that way sometimes. Put a voltmeter on the power supply to check (or take it to Radio-Shack) but it is probbaly the router itself
JOAT
Posted on Oct 16, 2009
Software for wgt624
WGT624v4 - Firmware Version 2.0.13
  • Only for WGT624v4 - Do not use on earlier versions of WGT624 (v1,v2,v3)
The complete information including easy to follow instruction how to download , how to install the software, how to upgrade etc....
Visit the netgear support website ,below is the direct website address
http://support.netgear.com/app/answers/detail/a_id/806/~/wgt624v4---firmware-version-2.0.13
Oct 13, 2011 | NetGear WGT624 Wireless Router
Netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 27, 2010 | NetGear WGT624 Wireless Router
Trying to find the download installation disk for netgear wgt624 v3
Everything for your model is HERE.
Hope this helps!
--RescueTechLA
Nov 28, 2009 | NetGear WGT624 Wireless Router
My WGT624 v3 has no power, seems dead
JOAT
Oct 16, 2009 | NetGear WGT624 Wireless Router
WGT624 v3 transmits no wireless signal.
You have to set up your router again. The id will be "admin" the password "password".
See manual" http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Feb 19, 2009 | NetGear WGT624 Wireless Router
Have no set up instructions for the wgt624 wireless router
do you have the cd that came with it? if not, everything can be downloaded here
http://kbserver.netgear.com/products/WGT624v1.asp
there 4 different routers in the wgt624 family. this is the first. check your label to be sure it isn't a later model chipset such as v2, v3, v4. if so use the download link at the netgear site to get the correct downloads for your specific model.
Nov 30, 2008 | NetGear WGT624 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
165 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
