Question about Microsoft Mlf Visual Studio Enterprise Edition 6.0 (628-01289) for PC
I want to map ip to hostname in visual basic 6.0 code can anyone know any library class which will resolve the DNS names in VB code pls send me mail as soon as possible
  • 289 Answers
This is handled by the "hosts" file on a machine. That file lives in the folder: C:\Windows\System32\drivers\etc
This file (named "hosts") is there for this purpose. You can modify it as you would any text file using VB6. Just be sure to maintin the file's contents format.
Posted on Apr 22, 2009
I find the ip of my Copier Canon imageRUNNER 550, I love to network so that I print, I can do, thanks
Windows XP (also Windows 2000/NT4):
  1. From the Start menu, select Printers and Faxes. (Windows 2000/NT4: Start menu, Settings, Printers)
  2. On the left side of the window, in the Printer Tasks section, click on the link for Add a Printer.
  3. In the Add Printer Wizard window, click Next.
  4. In the Local or Network Printer window, select Local Printer. Uncheck 'Automatically detect and install my plug-and-play printer'. Click Next.
  5. In the Select a Printer Port window, choose Create a new port. From the Type of port list, select Standard TCP/IP Port. Click Next.
  6. In the Add Standard TCP/IP Printer Port Wizard window, click Next.
  7. In the Printer Name or IP Address field, enter the DNS hostname of your printer (ex: myprinter.chem.cmu.edu). The Port Name field can usually be anything you like (without spaces), like 'lp0' or 'print' or the DNS hostname. Click Next.
  8. Click Finish. It may take a few moments before the next window appears.
  9. From the Manufacturers list, select the printer model of the printer you wish to use. From the Printers list, select the model number of your printer, followed by the designation (ex: HP LaserJet 4000 Series PS). Click Next.
  10. If you are asked whether you want to keep an existing driver, select Keep existing driver, then click Next.
  11. In the Printer name field, put the DNS hostname of the printer. This is actually the display name of the printer for just this machine and can be anything, but it's a good idea to set it to the DNS name as a visual reminder that it's an IP printer that can be used from anywhere. Most IP printers also have built in web servers that display status information about the printer, so recording the DNS name here can be a reference to use when typing in the printer's web address, like http://myprinter.chem.cmu.edu.
  12. If this is the printer you will be using most often, select Yes to use this printer as your default printer; otherwise, select No. Click Next.
  13. If you are asked whether you wish to share the printer, select Do not share this printer. Click Next.
  14. When you are asked whether to print a test page, select No. Click Next.
  15. Click Finish.
  16. If you receive a message that a Microsoft digital signature was not found, click Yes to continue the installation.
  17. To check if the printer is working correctly, go to Start > Printers and Faxes. Right-click on the newly created printer and pick Properties, and choose Print Test Page.
Mac OS X:
  1. Find the printer's full DNS name using the instructions at the top of this page.
  2. Go to Applications, Utilties, Printer Setup Utility.
  3. Click Add.
  4. Select IP Printing. Some inkjet printers may install their own section, like 'hp IP Printing' or 'Epson IP Printing'. If so, select that instead.
  5. Leave the printer type at its default value of LPD/LPR
  6. In the Printer Address field, put in the full DNS name off the printer, such as myprinter.chem.cmu.edu.
  7. Leave the queue name blank.
  8. Select the appropriate printer model. (If your printer model isn't listed, download and install the OS X driver for your printer from the printer vendor's website and go back to step 2)
  9. The display name of the printer can be anything, but it's a good idea to set it to the DNS name as a visual reminder that it's an IP printer that can be used from anywhere. Most IP printers also have built in web servers that display status information about the printer, so recording the DNS name here can be a reference to use when typing in the
Apr 16, 2011 | Canon imageRUNNER 550 Printer
Tip
CMD for Your Network
use this procedure cmd and make your Network Fix.
Berikut adalah perintah-perintah pada Command Prompt yang berhubungan dengan jaringan
komputer.
Untuk melakukan perintah-perintah tersebut Anda harus masuk ke Command Prompt ( Klik Start
->Run ->Ketik CMD )
1. ipconfig /all
Menampilkan informasi konfigurasi koneksi, misalnya Host Name, Primary DNS Type, Ethernet
Adapter LAN.
2. ipconfig /flushdns
Menghapus DNS Cache
3. ipconfig /release
“Menghapus” semua koneksi IP Address.
4. ipconfig /renew
Membuat IP Address baru untuk adapter tertentu.
5. ipconfig /displaydns
Menampilkan DNS Cache.
6. ipconfig /registerdns
Melakukan refresh DNS dan meregister kembali koneksi DNS.
7. ipconfig /showclassid
Menampilkan informasi DHCP Class.
8. ipconfig /setclassid
Mengubah DHCP Class ID
9. control netconnections
Menampilkan Network Connection.
10. nslookup
Mengetahui alamat ip address dari nama domain yang di tuliskan
11. netstat
Menampilkan informasi koneksi TCP/IP yang sedang aktif.
12. route
Menampilkan local route.
13. hostname
Menampilkan nama komputer.
14. ping
Contoh: ping www.finderonly.com
Melakukan test koneksi ke situs www.finderonly.com.
Semakin sedikit % loss-nya maka semakin baik koneksinya.
15. tracert
Menampilkan informasi IP Address route.
on Apr 27, 2010 | Computers & Internet
I need library management source code in vb 6.0
Please Download it from here!!
Don't forget to vote!!!
Regards
Vikas Agrawal
MCA
Dec 27, 2009 | Microsoft Visual Basic 6.0 for PC
Mapping of D-link DNS-323 drive doesn't succeed.
I had the same problem when I was attempting to map the drive using the hostname of the DNS-323. I solved the problem by typing in the IP address instead. Do the following:
1. Login to the DNS-323 as admin
2. Make sure you use static IP's to make sure that the address does not change in the future.
3. Go to the drive mapping page and use IP address instead of hostname in the drive mapping (e.g. \\192.168.1.1\Volume_1)
4. Make sure you use a valid username and password.
5. Check the connection configuration by clicking on the Test button.
You should get a successful outcome, otherwise check all the settings again until you are successful
Nov 20, 2009 | D-Link Dns 323 2-Bay Network Storage...
VIDEO LIBRARY MANAGEMENT SYSTEM source code IN visual basic
You can get your project from
http://www.planet-source-code.com/vb/scripts/ShowCode.asp?txtCodeId=70428&lngWId=1
Nov 09, 2009 | Microsoft Visual Basic 6.0 for PC
DNS help...
DNs (Domain Name System)
DNS is used for resolving mapping between IP addreses and host names.
Means when you quary for yahoo.com computer only recognize bits and bytes format so but dnd resolves this isssue when it got yahoo.com quary it send request to ip addreses of yahoo.com.
If you change dns ip to that then all quary goes to tht dnd server if it has info for your quary then it forwards to there other wise you get page not found.
Aug 22, 2009 | 3Com 3CR858-91 Office Connect Cable/DSL...
How can i download visual basic 6 soft ware freely
Dear friend take a look to these links, I hope they help you:
http://www.youtube.com/watch?v=y4F_rPu0ddU
(Through this video you'll learn how to download VB 6.0 free)
http://www.developers.net/tsearch?searchkeys=visual+basic+6+free+download
You can aslo download Express version of VB via this link:
http://en.kioskea.net/telecharger/telecharger-104-visual-basic-express-edition
Good luck
Feb 24, 2009 | Microsoft Visual Basic 6.0 for PC
Where can i download a vb 6.0 for free?
http://www.download.com/Jetpack-Visual-Basic-6-0-/3000-2206_4-10027981.html
GO TO THIS LINK N DOWNLOAD VB 6 FOR FREE
ENJOY
REGARDS RAHUL
Feb 21, 2009 | Microsoft Visual Basic 6.0 for PC
Getting error while joining any host(winxp or other os) to domain
Hi irudayaraj, you are right,and one more for checking use this http://www.whoisxy.com/ site ,really it is goos and free site.
Feb 15, 2009 | Microsoft Windows Server Standard 2003 for...
Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Jan 31, 2008 | Samsung CLX 3160fn All-In-One Printer
Microsoft Mlf Visual Studio Enterprise Edition 6.0 (628-01289) for PC Logo
234 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
