Question about Hotpoint First Edition WMA12 Front Load Washer
Hotpoint first edition washing machine door will not open after completing its full cycle
  • 566 Answers
Hi from the uk susan ? this is not uncommon and easily fixed if you are confident DIY ? and req's a little patience with a posi drive screwdriver if you want to save $$$$s on call out fee ? the problem is most probably the time delay switch which prevents door opening too soon after cycle/machine has finished and the light has gone off then door can be opened if you feel confident ? will help/instructions on how to rectify fault if you reply back ?
Posted on Apr 15, 2009
Door lock light flashing wont do any programme
Posted on Oct 09, 2010
Hi i my machine wma20 makes noise as it has lots of bricks inside it when starts spin?
Posted on Aug 12, 2009
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Door stuck
try unplugging and plug back in to reset
Nov 17, 2009 | Hotpoint First Edition FEW12 Front Load...
THE DOOR ON MY HOTPOINT WMA64 DOES NOT REGISTER AS BEING CLOSED
The most common cause of this is the sensor wire inside has vibrated loose and is no longer making a connection to the switch. Those switches rarely fail. It's a very easy fix, only need a screwdriver. I would, however, use a small plastic ziptie to hold the wire to the switch.
Oct 06, 2009 | Hotpoint WMA64 Front Load Washer
Machine does not complete the wsh cycle and we cannot open the do
f02 is a motor problem.
may need new brushes after 4 years use.
Jan 26, 2009 | Hotpoint  Standard Range Hood
Hotpoint 800 wm 11 goes through cycle but won't spill or drain
hi there maybe your waste pipe might be blocked from washing machine or mqaybe there is a blockage somewhere else in your plumbing which does happen queit alot? hope this helps
Jan 11, 2009 | Hotpoint First Edition FEW12 Front Load...
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
Smell coming from washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Hotpoint First Edition WMA12 Front Load Washer Logo
639 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
