Question about Maytag PYE2300AY Electric Dryer
Coin operated dryer won t turn off at end of cycle
    President:
  • 1,865 Answers
Most likely the timer needs to be replaced
Posted on Apr 15, 2009
HOW CAN I FIND A UNIVERSAL COIN BOX FOR GE COMMERCIL DRYER?
Most Appliance part stores can get you a coin box. If you have none local, google one of these sites and they can help.
V & V appliance parts
Repair clinic
Marcone appliance parts.
Sears appliance parts
Feb 21, 2015 | GE Commercial DCCB330EJWC 27" Coin...
Coin operated dryer
replace the belt.
Feb 02, 2014 | Washing Machines
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
The duration on commercial kenmore coin operated dryer isn't long enough to dry the clothes. How do i lengthen the cycle time?
Some dryers require timer cams to extend the cycles. The electronic dryers are programmable. The owners manual will tell you how to change the times. The owners manual can be downloaded at www.searspartsdirect.com.
Kelly
Mar 21, 2011 | Dryers
How can I adjust the run time per $1 on my maytag coin operated dryer. I would like it to run about 15 minutes per $1. Now is runs about 45 minutes on one $1.
Download this manual:
http://www.fowlercompanies.com/servicemanuals%5CMDG16SERVICE.PDF
The mechanism adjustments start on page 20. Note that the maximum number of slider cycles is 3. If you have a PD coin drop model the Max you can get is $0.75 per load I would have to assume that a different coin op mechanism may have to be used or one that will accept 2 coins per cycle for 2 cycles. On non PD models you can adjust the slots for as many as 4 coins per glide / slider cycle.
Thanks for choosing FixYa.
Kelly
Oct 20, 2010 | Dryers
Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Maytag PYE2300AY Electric Dryer Logo
125 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
