Question about HP Photosmart C7280 Printer
C7280 printer wont recognize newly inserted ink cartridge! HELP
After getting a message that the cyan ink cartridge needed to be replaced, I did just that. However, now every time I try to print I get an error message saying that the cyan ink needs to be replaced! It also allows me to select "print in black only" both on the LED of the printer and on the printer screen on my computer but says that after selecting that option a few more times I won't be able to print at all. I have tried cleaning the heads, I have tried turning the printer off and on....dont know what else to do. Moreover, this ink is so expensive, I do not want to have to buy a new cartridge. It was a brand new HP ink cartridge that I bought recently from Staples. Can you please offer a suggestion as to what I should do???? THANKS
  • Anonymous May 10, 2009
    I've got the same problem with a new Cyan ink cartidge not being recognized with this same C7280 HP printer. The printer itself will scan color docs and print them out in fine color, but when I try and send docs from the PC to the printer, the replace ink cartridge window appears and will only allow printing in black ink only.
    HP tech support is a joke, as the long distance connection is bad and the conversations were eventually, or conveniently, cut off when the 'your printer's out of warranty' issue was mentioned, but I digress.
    What was the rest of the advice for lauren728's problem, as that message was only partially available? Clean the contacts and ???
    Champion:
  • 214 Answers
Try cleaning the gold contacts on cartridge with DISTILLED water and cotton bud, allow to dry and reinsert. Make
Posted on Apr 23, 2009
Epson ink cartridges, always empty?
Epson has gone to great pains to ensure that third-party cartridges dont work. They really did a good job. Sometimes their printers wont even recognize genuine Epson cartridges. I saw a CX8400 with a brand new cartridge claim it was out of cyan ink after printing one 4 x 6 photo. Then it would recognize any cyan cartridge. It had to go back to Epson for replacement. Sign in China com Online Wholesale for AD Signage Product
Apr 22, 2014 | Office Equipment & Supplies
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Lexmark pro 705 wont recognize cyan ink
Make sure that you're using genuine Lexmark cartridges. If you are, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Reseat the printead again and the cartridges then reboot the printer. If it doesn't help, try replacing the cartridge.
Apr 25, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
I inserted non-HP cartridges into my C7280 printer and the display says "the ink cartridges appear to be missing or damaged", If I put the original HP cartridges back in, the error message...
Turn off your printer
Open the cover
1 .move the cartridge carrrier manually to the center manually with your hands from left to rgiht ( 5x )
2 .Open the cartridge carrier Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean specially the gold plate .CLean also the area where you return your cartridges also the contacts on the cartridge carrier make sure its clean OK .
Then return it again
You may also do that when your printer is on
1 . Open the cover first wait for the carrier to move to the center
2.thats the time you will remove the cartridge and clean and clean the cartridge carrrier
3.open again the cover reinsert the cartridges
make sure its close properly
Hope it help ..
If still nothing happens probably you have a fake cartridge which is not recognized by the Hp printer Ill be advising you to return it back and asked for a replacement OK
May 28, 2011 | HP Photosmart C7280 Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Ink cartridges not being recognized
Yes it says Cyan not installed
I have installed 3 different ones and same message
Oct 29, 2009 | HP Photosmart C7280 Printer
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
HP Photosmart C7280 Printer Logo
540 people viewed this question
Seeker5211
Seeker5211
