Question about Garden
Wont start I put in a new spark plug.Clean gas.Sometimes it wants to sart but wont keep going.Its getting lots of fuel.
  • Anonymous Apr 16, 2009
    i HAVE THE SAME PROBLEM CAN IT BE THE STARTER I READ SOMWHERE ITS PROB THE COIL CAN SOME 1 HELP
    I have a ECHO PB-413T and it doesnt start I cleaned the carbeurator the file line and nothing it sounds does any 1 has any ideas
  • 211 Answers
Hi
check the carburator inside,there is something blocked
Posted on Sep 23, 2009
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
I put 2 cycle gas in my 4 cycle Honda gcv190 pressure washer
did you pull the spark plug out and clean it ? if you did , did you also put the starter cord and turn the motor over without the plug installed to get rid of the 2-cycle oil out of the cylinder ? if not do so.
Jul 19, 2013 | Honda GCV190-N5AP 187cc GCV190 Series OHC...
My gas trimmer starts but wont stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
I have a 1999 honda accord w/ v-tech 6cyl engine. It occasionally wont start even though its getting gas and spark. I can sometimes sart it by pushing the gas pedal to the floor then starting.. the...
You need to check your fuel filter, if it hasn't been replaced in a while replace it. Also hook a fuel pressure gauge to the fuel rail to check if your regulator is flowing the right amount of fuel. Check the fuel pump, it could be going bad and is ready to fail.
Apr 29, 2011 | Honda Accord Cars & Trucks
1993 volvo 760 getting gas and spark,but still wont start.
Its easy enough to check for spark but how are you checking that you are really getting gas. Are the spark plugs new. If so the check that you have the right ones. It is not uncommon for a parts guy to give you the wrong plugs . If the plugs are not new and the car was running fine with those plugs before all this happened and the plugs look fine now, no bad, black carbon deposits then lets move on . Did you just put gas in the car. sometimes you can get a load of bad gas, I mean water in the gas when I say bad. Been lots of rain lately and this does happen. Pull the plugs on the car and spray some starter fluid down the cylenders. Replace the plugs and turn the engine over. If it fire up for a second or two and then quits, I would start looking at the fuel system. The fuel solinoid relay, which would supply power to the fuel pump could be a problem. Be sure you are getting fuel in the cylenders.
Sep 18, 2010 | Volvo 760 Cars & Trucks
Wont stay running
You might have water or dirt in your carb. Sometimes its the fuel can that is the problem. Your mower is new...but your gas can is old!
The first thing I would suggest doing is find the carb and remove the bowl located underneath it. Unplug spark plug for safety too!
Let a little fuel leak out of the carb with the bowl off to clean the fuel line coming into the carb. It may just a have a little dirt or rust blocking it. You can raise and lower the float on the carb to see if it moves freely and fuel stops and starts like it should, raising the float should stop flow an letting it hang down should start the flow.
If fuel flows freely then put the bowl back on, wipe up any spilled or pooled gas, and reconnect the spark plug. See if this clears things up.
If draining the carb bowl works you should go back and inspect the gas can and your mowers fuel tank for contamination. Chances are you have a layer of water down in the fuel tank and gas can. Empty the mowers gas back into the gas can and dispose of this fuel at a gas station that recycles waste fuel and oil. I would also suggest buying a nice new gas can if you old one is rusty, cracked or missing the proper vent caps that keep gas from getting all loaded up with moisture and dirt.
Good luck and be careful!
Jun 24, 2010 | Poulan Pro " Pro" Self Propelled Mower
I put diesl gas in my nissan altima... I drained
You are probably going to have to change the spark plugs. They could have gotten fouled out from the oil based fuel.
Oct 22, 2009 | 2000 Nissan Altima
My bike wont fire
First put a nail in the plug boot and hold it close to the engine and crank it over to see if you have spark to the plug, if you do, pull the spark plug out and see if it's wet. If the plug is dry put about a teaspoon of gas in the plug hole and put it back together, it should run for a few seconds. If it does that you have a fuel supply problem. It may have a fuel shutoff valve inoperative, or a carburetor problem. If you have no spark to start with and the plug is wet with gas, you have an ignition problem. If the exhaust smells like gas you are probably getting lots of fuel, but the spark plug can tell us lots of things. A new spark plug probably won't hurt either.
Jordan
Sep 30, 2009 | 1986 Suzuki LS 650 Savage
I have a 98 honda foutrax 300 4 wheeler it started acting up and now it wont start took the carb. off and cleaned the jets and everything up and pulled the spark plug out and put my fire over the hole and...
remove all of the old fuel using a siphon bulb and hose. Put in brand new fuel and make sure the line from the tank to the carb. is flowing gas. if not clean or replace the fuel line
Jun 17, 2009 | Honda NS 250 R Motorcycles
Tiller has sat in weater for a year. I changed the spark plug, and found there was water or gas in the oil (lots of it) i drained the oil and put in fresh but now it wont even start. what is my problem or...
You need a few things for a combustion engine to work. Firstly you are going to need to know a little about engines and how they work.
Fuel - try draining the tank and putting fresh fuel in it - fues does go stale. This will include fuel in the carburetor so that needs drained too. There was liquid, assuming water in the oil, perhaps it is in the fuel too.
Fire - do you get a spark to the spark plug? Pull the plug out and see if you get spark when trying to start - remember the earth of the spark plug needs to be touching the grounded metal such as the engine or frame. Perhaps the electricals have been water damaged.
Air - clean out the air filter and surrounds.
You have already drained the oil and replaced it - good start.
Maybe something has corroded since it has been in the weather for so long.
If it still does not want to start, try pulling out the plug & trying to start - is anything spitting out the spark plug hole? If so, what?
Once that is clean and clear and it still doesn't start but you have spark, try putting a bit of fuel carefully in the plug hole, say half a tablespoon.
How does that go?
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
