Question about Kenmore 15358
Sears Kenmore Sewing machine model 15358 Just got this machine brand new yesterday. I've gone through the manual very carefully to make sure the machine is threaded properly. It's very similiar to my old kenmore I bought back in the earlier 70's. Some slight threading differences but close to the same. anyhoo, I've done all the necessary adjustments inclucing tightening the bobbin by turning the little screw all the way and still the bobbin tension is too loose. I have to tighten the top thread tension wheel all the way to 8 or 9 to make it a little better. I'm using a size 14 needle on a med weight cotton fabric... Any suggestions or others with this problem? thx, cj
The tensions must match ie. top tension =bottom tension. If the material is not sewn together tightly, that means the tensions are mismatched. Sewing machines will sew whenever the top and bottom tensions are equal (be it very tight or very loose).
We usually advise the customer to not touch the bobbin case tension. When that is not changed, all tension adjustments can be made from the top tension above the needle.
It appears that one of the two tensions (top or bottom) is much tighter then the other. I would reset the tensions to how they came, if you are unfamiliar with sewing machines this may take a little bit of experimenting until you get it back to a standard quality stitch.
The other option would be bring it to a sewing tech. A good mechanic should be able to adjust the machine and your tensions to your fabric (and recommend needle size for your thread/materials) in about an hour.
Posted on Apr 15, 2009
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
I'm trying to oil my machine, but don't know how to get the face cover off??
Perhaps the Owner's Manual will help:
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/38515358.html?p=1
Be sure to use good quality sewing machine oil and white grease as explained in the manual.
P.S.--from the manual's instructions, it appears that you do not need to remove the face plate to oil your machine.
Sep 14, 2015 | Kenmore Sewing Machines
It's model no#158.10401.It just needs some care but would like a manual
If you scroll down the page, you will find a manual at this web site:
http://www.kenmoresewingmanuals.com/kenmore_158_manuals/kenmore_158_manuals.htm
Or, you might want to contact this company. They say that they have a lot of sewing machine manuals available:
http://www.sewingpartsonline.com/kenmore-158-10401-sewing-machine-parts.aspx
Here is some information about your Kenmore sewing machine model. It's probably a very nice basic machine and if properly maintained will last many more years.
https://stitchnerd.wordpress.com/2011/06/16/sears-kenmore-158-10401-model-1040-sewing-machine-a-review/
Jun 01, 2015 | Sewing Machines
Please show a list of kenmore sewing machine manuals
This should be most of the Kenmore sewing machine manuals.
010
1020
1030
1040
1045
1050
1206
1230
1232
1240
1250
1300
1357
1430
1431
15/I649
15243
15343
15358
1625
1641
1660
17920
17921
17922
1940
1941
1947
19501
19502
200
38
385.17622
385.19000
385.101118
385.115518
385.11607
385.11703
385.12614
385.15202
385.15208
385.15243
385.15343
385.15358
385.15408
385.15512
385.15516
385.160201
385.16120200
385.162213
385.166551
385.16677
385.16765
385.19005
385.19365
519
ELITE
14
1500
15218
15616
15718
1600
1650
1651
1652
1654
1750
1791
18
385
385.17620
385.17624
385.17630
385.1 521 2
385.115418
385.12314
385.151082
385.15358
385.161302
385.19005
68
95
96
SWA/RS 10101
SWA/RS 11101
SWA/RS 12551
SWA/RS 12621
SWA/RS 14401
SWA/RS 14501
SWA/RS 14502
SWA/RS 14571
SWA/RS 14572
Oct 02, 2014 | Kenmore Sewing Machines
Ibuy a used machine and need the user manual what i have to do
google search; kenmore 15358 sewing machine manual then down load the one you want
Apr 04, 2014 | Kenmore 15358
I NEED THE USER MANUAL FOR THE 15358
http://www.shopyourway.com/manuals/140371 is the service manual
http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0908315.pdf is the owner's manual
Model No. 15358. I am having problems with my
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Sep 04, 2009 | Kenmore 15358
E1, E2 error messages after needle breaks. Cleaned everything as good as possible, still getting message. I have a Kenmore Model 385.19233
Theirs a problem with the fuse on those machines. The e1 indicates that a fuse has been blown. check out the link for more details.
http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Aug 31, 2009 | Kenmore 19233 Computerized Sewing Machine
Thread goes off screw when i start sewing
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Kenmore Owners Manual
Jul 03, 2009 | Kenmore 15358
Kenmore 15358 Logo
709 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
