Question about Motorola Mobility V220
Motorola V360.. i need to empty the memory
I need to empty the memory in order to continue my ability to send text messages & take pics. i have cleared all of my texts and deleted some pics, but now it claims i have no memory left, therefore i can't perform any tasks except phone calls. Thanx.
  • naomi34 Nov 17, 2007
    msg memory meter problem and cant send or recieve texts
    Brigadier General:
  • 7,752 Answers
You need to reflash the software on the phone
Posted on Jul 03, 2008
6ya staff
SOURCE:
Cant change my messaging from dictionary to odinary text
To disable predictive texting on Motorola V360:
  1. Select the "Texting," "Text Messaging" or similar option on the menu screen.
  2. Choose the "Text Options" or "Options" selection on the "Text Messaging" screen. Choose "New Message" or "New Msg" if no "Options" selection is available, then press the button associated with the "Options" selection found on the blank message screen.
  3. Select "Entry Mode" on the screen. A list of options appear.
  4. Select a non-iTap mode, such as "Symbols" or "abc2." Press "OK." The iTap entry mode is disabled.
Jun 27, 2011 | Motorola Mobility V360 Cellular Phone
My inbox on my razor phone says no messages but memory full
I mentioned this in another area. We just got my son a motorola razr v3m, verizon. Any time he tried to check his inbox (which is text) or tried to send a text it would show memory full....this was the same if he tried to take a picture and send it.
First take out your battery, with the battery out, hold down you on button for like 15 seconds to drain the phone of juice, then put your battery back in it and turn it on. If this did not reset your phone, and if you are on verizon as your carrier, then you need to call them and make sure that they have you set up on their text messaging program. It used to be that if you didn't have, then they would charge you .20 cents a text, but with some of the razr, such as the v3m, you have to actually be on a monthly text plan to view inbox, send text, send pics, and receive pics and texts.
Nov 03, 2009 | Motorola Mobility RAZR V3m Cellular Phone
My phone won't let me send a text message.
my motorola wont let me send or recieve texts and when i try a banner comes up and says memory full I've deleted pic, and all messages what else could be wrong.
Nov 02, 2009 | Motorola Mobility Boost i415 Cellular...
My phone keep sending duplicat messages
got to the security menu and perform a master reset...this should stop the duplication for at least a day or so......if it continues you must contact your provider to have them reset your MDN on their SMS system.......all that means is they will delete your ability to send txt for a few seconds and resubmit a query to their system to have sms ability...........now you should be good to go. most service providers have seen this before and should understand the process or refreshing your sms and data settings
thanks and pls rate this post
Oct 03, 2009 | Motorola Mobility RAZR V3
Motorola V360 -Memory card slot error
Hai Dud,
Are you using Micro SD transflsh memory??
Format the Card on the PC using FAT, after that use a CARDREADER and put these folders on the card: MOBILE and in the mobile folder put audio, video, kjava, picture, temp! Shutdown your Motorola, remove the backcover and plug-in the card! After that Start Your Motorola and copy a file from the mobile's memory on the CARD! It should work!
Hope it Helped You,If so give an "High Five!" [;)]
Aug 04, 2009 | Motorola Mobility V360 Cellular Phone
MOTORAZR V3m "Memory Full"
DELETE YOUR COOKIES AND TEMP INTERNET FILES
Feb 17, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola V360 Text Freeze
no, try the master clear first..its in initial set-up i think
Jan 03, 2008 | Motorola Mobility V360 Cellular Phone
Text messinging
The shared memory of your phone might be full,
Please see the no. of applications using the shared memory in your user guide and try to clear it.
Which phone do you use???
You must specify for a better solution!!!
Please rate if satisfied and don't forget to incude the model of your phone next time!!!!!!!!!!!!!!!!!
Dec 16, 2007 | Motorola Mobility V360 Cellular Phone
Motorola V360 Sending Pic Messages/Emails
in order for me to help you i need to know your location & the network that you are using. ( if you are in South Africa only then can i help)SO PLZ POST BACK.
Feb 07, 2007 | Motorola Mobility T-MOBILE V360 Flexible...
Motorola Mobility V220 Logo
192 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
