Question about Canon imageRUNNER C3220 Color Copier
Filters??? Someone said that I need to change the filters on the Imagerunner C3220. What filters are needed and what are their purpose? Thanks
  • 469 Answers
Ozone filters, they filter out the ozone produced by the copier. This reduces the ozone output, and smell. But ii also traps dust, if the filters plug up it can reduce copy quality as well as emit more ozone into the work space.
Posted on Apr 15, 2009
Tip
The best a/c filters to use
The absolulte and only filter any tech would be the cheapest ones avalaible in packs of four or more for less than a dollar each.
These filters give your system the best air flow and protect you system well. The purpose of air filters is to protect the equipment.
If someone in your house has breathing problems or dust is a problem; Spray the filters with a dusting spray which will give it that chemical magnetic power.
All filters should be changed monthly as they become breading ground for dust mites and mold spores. Using cheap filters, changing them monthly is the key.
Having plenty on hand, as they are cheap, makes this the only way to go,for making this an easy task.
A good monthly reminder is when you recieve your electric bill change the filters.
Your a/c system will love you for it!
on Jul 08, 2010 | Heating & Cooling
Error Code E00110-0110 "Canon C3220"
The only way for you to resolve this problem is to access the yellow laser motor. Unfortunately, you need to remove the laser and check for rotational operation and replace if necesary. That's it - no one can do that for you but you.
Sep 23, 2009 | Canon imageRUNNER C3220 Color Copier
Ghosting image on canon c3220
Suggest to check the transfer unit. Especially the transfer cleaning blade..
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
My canon c3220 is giving me a "ghosting" effect on b&w copies any ideas?
Did you change ink cartridge? If yes you need to go thru a print set-up cycle to reset the printer
Cannot download C3220 to computers
try to visit the www.canon-europe.com download drivers your machine IRC3220 or CLC3220
Apr 16, 2009 | Canon imageRUNNER C3220 Printer
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Dirty drum
change to thick paper in add function
Jul 17, 2008 | Canon imageRUNNER C3220 Printer
It doesn't print some pdf files from our computer
you can try to use the postscript driver, it should proccess it better. If you need to use pcl driver change the driver setup... under the properites of the driver click port tab... click config port....click lpr and in the Queue name type...print
this should help if not you may need the service tech. to upgrade software rp
Mar 19, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
96 people viewed this question
old marine
old marine
