I purchased a motorola s9 headset for my motorola krzr phone & I was able to pair it together & it works to make phone calls but it does not allow my to listen to my music on it. I go to my music on my phone & press play but it does not send the signal to the headset it only plays thru the phone?????
-   krave wont send music through stereo headset: lg hbs 110
-   Guest
Apr 28, 2008
-   I have the same problem with the blackberry Pearl. It actually worked great for streaming music and phone call for one week, and then it stopped working for music. I got a replacement pair of headphones and they didn't work for music the first time I tried. weird.-   colino16
Mar 08, 2008
-   I bought the same headset nad did some research, the K1m does not have a2dp technology so it will not play music on any bluetooth headset, you will have to use the handsfree wired headset. -   Guest
Jan 12, 2008
-   Yeah, I have the same problem, too. Does anyone has any solution to this?-   Vego
I bought the same headset and also have a K1m, I did research and found out that the k1m does not have a2dp technology so it will not play music on any bluetooth stereo headset, in order to listen to music through a headset you will have to get the handsfree wired stereo headset, bummer
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer...
(More)
I locked myself out once because I needed a PUK code for the Samsung Impression, I called customer care service and then they gave it to me, when I put it in it said I had to change my Pin code, so I changed it and now I forgot it.
How do I change it again ?
i cannot open my camera..when open it, it says that i'm using other application so it cannot be...
(More)
i cannot open my camera..when open it, it says that i'm using other application so it cannot be open..why does that happen?
