Question about Maytag 24 in. MDB5651A Built-in Dishwasher
Cleaning screen filter for garbage disposal in dishwasher
I have had trouble with the dishes not getting as clean as they used to, so I looked at the screen for the disposal system in the bottom of the dishwasher and there are TONS of gunk and food particles stuck in there! I took the entire thing apart, but I cannot remove the screens to open it up to clean that area out. It's all supposed to work its way around to a little hole the size of a pencil eraser- but there's so much junk in there it's all stuck. How do I get into that area to clean it out? It looks like it's glued together (no screws that I can find to separate it). Any ideas??? Thanks!
  • Moenchick Dec 24, 2007
    Mine has beein doing this since we bought it 4.5 yrs ago. I am very displeased.
  • Anonymous Mar 07, 2008
    Same here. Had it for a year and 1/2
You can't take it apart. If you do it will only get worse. Check to see if there are any holes or tears in the screen. If so, replace that whole part.
Posted on Jun 07, 2008
We replaced our garbage disposal and now when we run the dishwasher the overflow valve has alot of water running out of it onto the countertop. Did we forget to do something when we put the new disposal in? help we can't run the dishwasher without staying by the sink when the dishwasher rinses or pumps the water out through the dishwasher
Posted on Apr 01, 2009
  • Bruce Denton Jan 28, 2011
    i realize its been years, but clean out the hose from the disposal to the airgap or its twisted
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
My dishwasher is not draining completely. There seems to be more water left than last time I used it. Also, I tried to used the cancel/drain feature, with no success. Please give me some suggestions!
Hi and welcome to FixYa, I am Kelly
The drainage problems are caused by particulate in the drain.
There are 3 areas that cause restrictions with larger food particulate
1. The Air-Gap (if equipped) but the most common blockage point,
2. The sink connection. This is usually a garbage disposal connection. If the user is not properly rinsing long enough while the garbage disposal is in use the garbage disposal / dishwasher connection port is blocked with garbage disposal debris.
3. The bottom of the dishwasher sump area under the lower wash arm. If this area is blocked the user will complain of dirty dishes post cycle, It also causes drainage problems, If the user says dishes are not getting clean and it is not draining properly this will be the LAST area to check. Do 1 and 2 first.
I have had multiple call backs on some units... I have learned to call a brief moment before stopping by and inspect the DIRTY dishes in the dishwasher, the sump, air-gap and sink connection. Most of the time I find that the user is placing dishes with large food particulate in the dishwasher or... they are not letting the water run long enough when using the garbage disposal so the garbage disposal port clogs. These are the same folks that have things like pump impellers and pump housings that get broken due to their daily routine habits.
You wil have to clean all of the drain connections for the dishwasher pump outlet all the way to the sink connection. The Air-Gap is the most common area for blockages so pull off the cover.. unscrew the inner top nut NOTING the installed position BEFORE removal and clean out the Air-Gap (if you have one) Otherwise remove the drain hose at each connection and remove the debris. It is OK ot reconnect each connection after your done cleaning. This will solve about 85% of dishwasher drain problems. The last 15% the lower wash arm and support has to be removed to inspect for pump impeller damage or motor pump housing damage.
FYI the 2nd most common reason for drain problems is the actual sink port connection being clogged. Just clean the drain hose connection ports and the air-gap.
I think once you get all of your drain connections cleaned that your dishwasher will operate normally.
Thanks for choosing FixYa,
Kelly
Jun 17, 2011 | Whirlpool Dishwashers
How can you tell if the disposal in the dishwasher is working properly or not working.
These really do not a conventional built in garbage disposal..there is a cutter that prevents things from getting into the pump area..it chops up foods into small enough pieces to get through..always rinse off your dishes first or you will be cleaning screens and having d/w problems..this will stop cleaning well when this thing gets all stopped up. Remove and clean the screen area and always rinse off your dishes.
Jan 28, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water not draining out
Look where the drain hose attaches to the garbage disposal. Make sure the knock out plug has been removed.
Feb 23, 2010 | Dishwashers
Dishwasher leaves film on the dishes
If your dishwasher is a few years old and just started leaving a film on your dishes there is a filter under the bottom adjitator that you have to replace it can't be cleaned jf
Jun 13, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
MY DISHWASHER IS NEW DISHES ARE DIRTY AFTER WASHING
Check the screen in the bottom of the washer for debris. Remove the screen and clean out the impeller with your hand or an old toothbrush. Also check your vent hose coming out of your garbage disposal. This can clog and cause problems. Hope this helps your problem.
May 14, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Kenmore Elite Not cleaning dishes
You might want to check where the hose from the air gap connects to the disposal there is a plug that has to be removed to allow for the washer to drain.
Mar 15, 2009 | Kenmore 24 in. 17303 Built-in Dishwasher
Garbage Disposal backing up in dishwasher
Most dishwasher have a check valve at the pump to prevent water from backing into the dishwasher. If the pump is electric there is a rubber flat that may be gone or not working properly. If that is the case you need to replace the pump. If the pump is part of the motor assembly then the pump and motor will need to be replaced. One other thing to make sure of is that you have the drain hose looped to the top od the dishwasher and then to the disposal conection. Its called a drain loop and all dishwashers should have it. Good Luck
Jul 11, 2007 | Frigidaire 24 in. FDB1250RE Built-in...
Maytag 24 in. MDB5651A Built-in Dishwasher Logo
1,026 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
