Question about Toshiba Satellite A60 Notebook
Satellite A60 turns off 2 sec after turning on; periodically
Turning ON, 2 sec later laptop turns off by itself. Funs are functioning properly, HD alright, RAM good, and power adapter, too. Furthermore, works perfectly once "somehow" it turns on the way it should. Then can turn on several times with no problem, but by some reason laptop seems to "decide" not to do so on particular "moon phases" :) In my opinion, laptop turns itself off during system check due to abnormal readings from some hardware part, or something like that ... just like sys wont boot if battery totally discharged and no adapter present, but what's particularly in my case? )
Have Toshiba Satellite A60.
  • 1 more comment
  • dr_mihelson Apr 16, 2009
    Thanks for reply. So, if I understood it right, then the problem is in the actual A/C connector located at the back of laptop? Or, the problem is after that connector? I was suspecting A/C connector myself for a while, but was not certain that such a small piece might cause such headache, besides visually it doesn't reveal that it might have any problems inside.
    Anyways, thank you for help, once again! :)
  • dr_mihelson May 22, 2009
    .... alright, the A/C connector was replaced by the new one. However, the problem seems to remain. Laptop started ones, then after turning it off laptop began to do the same "tricks" (shuts-off automatically before boot). Any ideas what other things may cause such behavior?
    my fault, by A/C I meant the connector that's located inside PC, not the charger .... the charger is out of question since I've tested it with the same laptop of friend of mine. So, to keep things clear, if I understood right, you meant the female connector at the back of laptop, to which the power adapter connects to, right? That's the part that was replaced .... the old one didn't seem "healthy" though, but did not solved the problem either )
  • 385 Answers
Sound's like your connection to the A/C connector main's is going, inside the Pc this is.
it is a Common problem on laptops,
Needs stripping out soldering, and re-build,
$200/250 ball park figure.
Regards.
Posted on Apr 16, 2009
  • 2 more comments
  • Richard Finney
    Richard Finney Apr 16, 2009
    Inserting and removing the cord, 365 days x 2,3,4, times a day uses the connection alot, and it fails because of this.
    So the inside of the PC is where the fault is,
    A soldering job at the minimum, new connector at worst.
    Strip out do the job, re-build.
    should be good.
    Regards.
  • Richard Finney
    Richard Finney May 22, 2009
    No you mis-read what I wrote,
    I wrote that the connector ( inside the Pc is faulty )
    not the charger
    Richard.
  • Richard Finney
    Yes inside the Pc, not the adapter,
    what happens is over say a year, in and out, with the adapter
    causes the connector inside the Pc, to faulter,
    it is only a tiny part inside, and when your in and out all the time with the adapter, the soldering to the connector can split and separate from the Motherboard,
    So, this is why your getting a dodgy connection,
    (ie: sometimes it works, sometimes it doesn't work )
    This is the connector inside that is catching sometimes and running, and other times, it will not touch/catch the connection,
    So, basically, the connector inside the Pc, is faulty,
    As I wrote $200/$250 repair
    Simple fault, painful and costly to fix, but it is where the fault is.
    I hope this explains it better for you
    Sorry, if I didn't explain it better for you.
    Regards
    Richard.
  • Richard Finney
    you can have the system checked, pretty cheaply to confirm this,
    I recommend this,
    Regards
    Richard.
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Toshiba satellite a60-111 wireless cannot activate either by switch of key function
http://209.167.114.38/support/Download/files_downloads/PSA60C/SA60EXUM.PDF
on page 4-29 (or 106 of the pdf) is where it talks about wireless. However on page 2-9 it talks about an orange glow to know your function is turned on. review the above manual and store for the future as I don't know who provides it.
Jun 13, 2011 | Toshiba Satellite A60-S166 Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
Laptop turns on for 5 secs then turns itself off. The Toshiba screen appears and 2 secs later turns completely off. Is this a virus or some other issue?
sound like power supply or battery. first try running the laptop on battrey if the problem persists, then pull battry and try running on Power Supply only. if problem is fixed then your battery has gone bad.
Oct 12, 2009 | Toshiba Satellite A135-S2276 Notebook
No power to Toshiba A60
Make sure the laptop is off, pull the battery, and just power it up with the AC adapter. Once you get it going, head over to the control panel, and check the settings in power management. It could be that the settings are wrong and it will not let you start it up with the battery installed.
May 04, 2009 | Toshiba Satellite A60 Notebook
Toshiba A60 shuts down in 3 seconds
Bios may be set wrong(fix by restoring default settings)
memory may be damaged(replace if true)
battery may be low and system shuts itself off(make sure battery is charged)
Drivers may be wrong(replace drivers in safe-mode)
Motherboard or other devices inside laptop may be loose and/or shorting.(Go to local computer fix-it shop or (open up laptop and check for loose connections which may void warranty.))
My guess is your bios needs resetting
Hope I am a help.
Feb 03, 2009 | Toshiba Satellite A60 Notebook
Laptop (Toshiba Satelite A60) keeps turning off
Is it turning off by itself after being on for 20min... each time? I.e. is it consistently turning itself off after the same amount of run time? Check the bottom of the laptop... how hot is it? Might be an over-heating problem. Some freeware (MobileMeter) might help you monitor temperatures and see if it is a problem
MobileMeter
http://www.softpedia.com/get/System/System-Info/MobileMeter.shtml
Some excellent heat management information here:
http://www.technowledgebase.com/2007/07/03/monitoring-your-laptops-temperature/
Jul 05, 2008 | Toshiba Satellite A60 Notebook
Toshiba a60 wont work with the interactive smartboard
YOU DONT HAVE ENOUGH RAM POWER WITH THIS COMPUTER MAX OUT THE MEMORY WHEN YOU UPGRADE
TO ATLEAST A GIG OR 512MB AT THE LEAST
Jan 18, 2008 | Toshiba Satellite A60 Notebook
Laptop wont turn on
You may check if the charger connection to the laptop is secured and doesn't have any problems. If the laptop doesn't show any sign of life,no led flashing, no nothing it is probably that your charge circuits or power on signal circuits are burned or broken. It sounds strange but they don't need a special motive to do that, they can simply die out. You will need your laptop dissasembled for this job and some knoledge of laptop electronics however. If you feel that this is not for you a service center can check the problem. Be carefull to specify exactly the simptoms you encounted. In worst case scenario they will asume your motherboard "dead" and propose a replecement. Be patient and try other service centers if this is the case.
Jan 12, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 Notebook Logo
433 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
