Question about OKI B4350 Laser Printer
Oki B4350 Error 020
As soon as the printer is turned on the screen reads ERROR020 and the printer will not do anything.
TIA
bshort1023
3 Suggested Answers
SOURCE: Error 020 on OKI B4350 printer
After pushing the on button, RAM CHK- initializing-- on-line - auto, and then, over and over and over again. It just goes in a circle.Pardon my english. Denmark is calling :-)
Posted on Feb 15, 2010
  • 87 Answers
First thing I check on the Oki LED printers anymore is the capacitors on the power supply. There are 2 types of power supplies used on the B4350's and others in the B4xxx series - one works fine, the other is nearly always the cause of odd errors. Open the top by opening the toner door, remove the toner/drum assembly and set aside, remove the screw on the smaller back cover and set the cover aside (screw stays captive with the cover) then up near where the toner was there are two clips, one on each side, that hold the main cover down. Dont break them, just get them enough to release the cover from the chassis. Lift the front of the cover up, unhook the back then lift up and off and set aside. Now take a flashlight the rear and look through the fan and to the left of it (as you look at the back of the printer) and you should see some skinny cans with a shrink plastic covering and a strip of "-" marks running down one side. Those are electrolytic (aka can) capacitors. Look at the tops of the two taller ones near the fan and see if the tops are perfectly flat (they are good if they are flat) or if they are bulging up, or even have some brownish residue on top and bulged. This is the typical sign of failure of the Chinese made capacitors anymore. IF you do see swelled tops or leakage then this is your problem and you can either replace the power supply as a unit (quite expensive) or if you know how to replace the capacitors you can get them from an electronic supplier. I have to use Digikey myself. There are actually three capacitors that fail, all in a group. There is a 1500uF 10v, a 270uF 50V and a smaller 56 uF 50V in between them that will also show swelling despite it's small size. You should use the same microfarad value but you can go one range up in voltage - NEVER go below the rated voltage on the original capacitor. I use the exact capacitance (uF) and voltage as the power supply is pretty tight on space and if you go up in voltage the size usually goes up. Also they are polarized - make sure you get the dashes on the correct side when replacing or they will explode. Once replaced you can test with the cover off but with the toner back in and the toner door down. If all is fine then open it, put the main cover and small cover on and run it.
Alternately if you dont find bad capacitors you will need the service manual to troubleshoot the error condition. One place that sells PDF manuals is justmanuals.com.
Posted on Jun 30, 2010
Error 020
Error 020 means its a problem with the main board(hardware) on the printer. you should contact printer manufacturer.
***If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 19, 2013 | OKI B4350 Laser Printer
En la pantallade la impresora oki B4350 me marca error 134
Tengo una Oki mc361/mc561 me da error 134 como puedo solucionarlo
Aug 26, 2011 | OKI B4350 Laser Printer
ERROR 020 HOW DO I FIX THIS
Visit to the given link. http://www.c5100n.co.uk/index.asp?printername=C5100n&menumode=0&content=errorcodes
If the error code you're looking for is not in the table (in above link) then send an email to support@c5100n.co.uk and we will find out what it means...
Hope this has helped you...
thanks....
Jul 18, 2010 | OKI B4350 Laser Printer
OKI B4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Feb 22, 2010 | OKI B4350 Laser Printer
Dec 21, 2009 | OKI B4350 Laser Printer
I just changed the toner and I now have an error code 020
020 is a CU rom error... check that your memory and PS cards are fitted into the main PCB properly, if not remove the PS card and try it. Beyond that you might have a faulty main board
Sep 08, 2009 | OKI B4350 Laser Printer
When printing all I get is a message saying invalid data (printer B4300)
I had same problem and when I installed OKI B4350 (PCL) driver it started working fine.
Before I had OKI B4350(PS) driver installed and it gave me invalid data error everytime I've pressed print.
I hope this works for you too.
Cheers,
T
May 22, 2009 | OKI B4350 Laser Printer
OKI B4350
Its a Thermal error. the code is Error 020 and its a problem with the main board on the printer. costly to repair if not under warranty
May 06, 2008 | OKI B4350 Laser Printer
OKI PRINTER B4350
This sounds like it could be a "toner Sense" error / try removing the drum unit and cleaning the 6 contacts on the left inside of the printer
Apr 09, 2008 | OKI B4350 Laser Printer
Oki B4300 LCD printer
Error 020 is a CU ROM Hash Check Error 1
It's most likely in need of circuit board replacement
If it's under warranty, contact the seller or
call 1-800-OKIDATA
Apr 05, 2008 | OKI B4300 Led Printer
OKI B4350 Laser Printer Logo
558 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
