Question about RCA P46922 TV
RCA P46922 No picture, good sound
TV worked fine, turned it on and no picture on any feed but sound is good. It will flash the channel while changing but that's it. This was a hand me down and I use it to watch the yanks and pay wii. Is it an easy fix or junk?
    New Friend:
  • 76 Answers
This is due to the screen will not get the exact grid voltage. Without getting the proper screen voltage black current section will not allow to flash the channel continuously. This can be solved by adjusting the exact G2 voltage. More the deflection area is free from dust and moisture to avoid the same problem infuture.
Posted on Sep 14, 2007
SOURCE:
My TV has sound but no picture... what are the solutions?
If audio output is OK, the fault must be to its horizontal output section. Check and replace horizontal output transformer, and associated damaged component/s.
Aug 21, 2012 | RCA TruFlat 27F520T 27" TV
TV Flashing from Channel to Channel Non-Stop. Problem with the RCA F32689 32" TV My TV started jumping from channel to channel non-stop. There's no picture or sound - only channel numbers changing...
If still under guarantee take it back.
If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
Sep 21, 2011 | RCA F32689 32" TV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
May 31, 2009 | RCA M50WH185 Television
My RCA TV Model F27442 has no picture
is it snow on screen? if so tuner  problems. rca had recall on tuners on some models bad solder connections in tuner
Dec 03, 2008 | RCA 32V420T 32" TV
TV turned black while viewing and then started clicking
bad IHVT AKA flyback transformer.Be sure to give complete service # for correct part #. Service # is three characters longer than the model #.
Oct 02, 2007 | RCA P46922 TV
TV went out
it shut down when was viewing ah..ok there is a short and could be in the horizontal circuit or in the power supply regulator any way thats a job for a tech...good luck
Aug 10, 2006 | RCA P46922 TV
RCA P46922 TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
