Question about Simer 1/3 Hp Submersible Sump Pump
How do you get it apart to install new electric cords?
Two screws on top hold the cord in below the handle. Repplacement cords are available.
Posted on May 02, 2009
    President:
  • 389 Answers
Not 100% sure about this, but I think you'll find the answer is... you don't.  In all submersible pumps that I'm familiar with, the cable is part of a unit that's sealed during manufacture so that water can't get in to the electrics.  If your cable is damaged, I think you have to replace the whole unit. Sorry! Of course, if you just want to extend the cable, you can get a waterproof connector.
Posted on Apr 18, 2009
What is your name who just responded to my question re: the Arist Craft power cord for my skillet?
http://www.fixya.com/users/claude-kayser
http://www.fixya.com/support/t25984520-need_new_power_cord_west_bend_skillet
West Bend Electric Skillet ' eBay
www.ebay.com/bhp/west-bend-electric-skilleteBayFind great deals on eBay for West Bend Electric Skillet in Electric Skillets. Shop with ... NEW West Bend WB1 Heat Control Sensa-Temp Power Cord Plug Probe ...
http://www.fixya.com/users/bill_boyd563
From a appliance repair shop
from e-bay
http://www.fixya.com/users/chris-storbeck
Usually the manufacturer's owners manual has a part list with phone numbers and part numbers available for replacement.
If the correct part is not available, you could buy a similar sized gauge extension cord to wire in place by taking the appliance apart and securing properly.
Last but not least and certainly not recomended would be to wire in that extension cord with wire nuts and then electrical tape together. Good luck!
Nov 29, 2015 | Kitchen Appliances - Others
I burned through the electric cord on my George Foreman Grilling machine. How do I replace the damaged electric cord?
take the grill apart and remove the old wires ( label and mark colors ),, go to your local hardware store and buy a pre made plug and wire set and install to the grill.
now depending on where the cord got burned -- you can just shorten the cord and use the existing cord -- ( it will just be a bit shorter ).
you can also use a extension cord and just cut the one end off of it and wire that to the grill.
or you can just cut the burned through part off and use **** connectors to put it back together.
c...
Feb 04, 2011 | George Foreman GGR50B Grill
Unable to install. Does it have an electric hookup because it did not come with an electric cord.
Hi, You have to take the cord off of your old dw and install on the new. In the right front corner of your new dw is a metal box. Take the cover off and install your cord using wire nuts. This should get you going. Hope this helps.
Jan 17, 2011 | Maytag Dishwasher
I broke th pull cord on my ryobi ss26 weed wacker.took it apart to restring is there a certain way it must go back together? does the cord through the little hole thats on the spool? if possible can i get...
There should be a hole in the pulley that holds the starter rope in the starter/recoil unit. If you have taken the machine apart to that point, yes, there is only one way to reassemble it.
You will have to wind the starter recoil without the rope installed on itabout 5-6 complete revolutions to "pre-load" tension on the spring-steel starter spring, then lock the pulley in place, insert the pull rope and tie it off so it can come back out and then release the pulley, letting it draw in the new starter cord. Make sure you have the handle installed so it will stop when it gets to the body of the engine cover.
Sep 22, 2010 | Ryobi 15" Electric Factory Reconditioned...
My power cord does not fit the electrical outlet in my new apartment _ maytag Neptune electric dryer. Is there an adapter to change the cord from 3 prong to 4 prong
You need to go to a local hardware store and buy a new cord. There is an adapter but it is more exspensive than the cord and I have seen problems with them overheating because of the fine dust getting in them. Your cord is easy to replace there is a access panel that is held on by a screw where the cord goes into the machine. You will need to remove the screws holding the electric wires there will be 3 on your dryer. The 4 wire cord has an extra ground. You can put this under the screw that holds the access panel on. The two outside wire connectors on your dryer are the hot wires each carries 110v the center wire is the neutral wire and also acts as a ground on a 3 wire dryer. The 4th wire is an ground for house trailers and some areas require them as a seperate ground from the neutral. I hope this helps
Aug 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a old Century electric motor and I am trying to install a new power cord. It has 3 terminals inside the cover plate and I need to know which are which. One has no wire, one has a blue wire and the...
The missing terminal would be a 'ground' usually apart from the other two. The blue should be hot(black on reinstall)yellow neutral(white on install) ground is green.Older electrics dealt with two wire hookups. Grounds connect to the motor metal body proper.
Aug 07, 2010 | Saws
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
Apr 12, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Simer 1/3 Hp Submersible Sump Pump Logo
96 people viewed this question
Top Simer Garden Experts
Dennis Key
Dennis Key
john h
Are you a Simer Garden Expert? Answer questions, earn points and help others
