Question about Sewing Machines
Sears Kenmore sewing machine model number 15358 tension issues
I've adjust the bobbin tension all the way to make it as tight as it will go.
Still the bobbin tread (bottom stitch) is too loose.
I've adjusted the top thread tension wheel to 8 or 9 and it still is too loose.
The topstitch looks good.
Bottom stitch seems to lay on the fabric surface ....isn't being pulled into the fabric barely if at all.
What am I doing wrong.
I'm using the needle that came with the machine (size 14)
The fabric is a cotton dinner napkin scrap.
Help anyone?
thanks,
cj
  • 1 more comment
  • burnsbart53 Apr 16, 2009
    I tried this tension test. It was as you said it should be.
    loose before the pressure foot was raised. I set the tension setting on 5. Also decided to loosen the bobbin screw a tad. I had it tightened as far as it would go.
    Still appears to be doing the same thing. Bottom thread still sitting on surface.
    Also am noticing the row of test stitches I did are not perfectly straight. Some are a bit out of line. Weird huh?
    help anyone?
  • Anonymous Apr 18, 2009
    O i'll try that and let you know what happened.
    Thankyou,
    Carol Jane
  • burnsbart53 Apr 18, 2009
    It appears to have helped a bit
    I still will need to fiddle with that bobbin screw to get it right (I think).
    The machine only cost me $99.99 plust tax and shipping. So it's not the top o'the line. Maybe I should have spent more money if I expected more expert results.
    I'll work on getting the settings just right and will decide if in the end it's good enuff.
    thanks for all you advise. It was helpful.
    Carol Jane
#14 needle is way big for cotton napkin scrap. a #10 is good for most lightweight fabric. #14 is for sewing denim or levis, like that.
the tension problems on almost all machines regardless of price usually fall on the upper tension. the lower bobbin tension is factory set and it's rare you should ever need to mess with it.
if you have a drop in bobbin (top loading), tighten the adjustment screw all the way and then back it off 1/4 turn. if your machine uses a shuttle bobbin, tighten the adjustment screw all the way and then back it off in 1/4-turn increments until you can hold it in the air like a yo-yo and cause to bobbin case to fall slightly dipping your hand.
A dull needle and stitch length will also mess up your stitch. The idea is to narrow the problem down to one thing and one thing only -- UPPER THREAD TENSION.
So, if you have the right size needle for the job, with the right thread, and if your stitch length selection is correct (usually between 2 and 3 or 8-to-10 stitches per inch, the problem should be with your upper thread tension.
An easy way to fix this then is to remember: Loops on top, upper tension drop. Loops below, upper tension grow. If you get loops on top of your work, lower (drop) your upper thread tension to a lower number. If you get loops on the bottom, raise the upper thread tension.
Different stitches on the same machine will require different upper thread tension settings. Don't be afraid of it. Just remember the pneumonic: loops on top, tension drop, loops below, tension grow -- referring to upper thread tension.
have fun :)
Posted on Apr 02, 2010
  • Sewing Machines Master
  • 1,388 Answers
Check this solution:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 17, 2011
  • 323 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You need to do a tension test
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Apr 15, 2009
  • John Free Apr 17, 2009
    loosen the bobbin tension screw some more. It is too tight.
    sewman7
How do I set the bobbin tension
How to change the tension on a sewing machine?
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine Search for: How to change the tension on a sewing machine?
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+How+do+I+set+the+bobbin+tension ..try this link
Dec 04, 2016 | Sewing Machines
Kenmore bobbin issues
try these suggestions
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Oct 25, 2012 | Kenmore Sewing Machines
I have been told that my Kenmore sewing machine, model number 158.1784080 won't maintain tension because the 1) bobbin case needs to be replace (easy to get, but not from Sears), the zig zag needle...
have you tried any of these sites
sewingpartsonline.com
sewvacdoctor.com
whitesewingcenter.com
sewingpartsdirect.com
sewingwarehouse.com
sewforless.com
Sep 19, 2011 | Kenmore Sewing Machines
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Hello
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
The bottom thread gets loose and tangles, just the bottom stitsch is not proper
This can happen when the machine is threaded with the presser foot down.
What looks like a problem with the bobbin thread is actually the top thead not seating into the tension control during threading.
When the foot is up, the tension opens and accepts the thead. When the foot is down, the tension is closed and then when you sew, the loose top thead cannot form a tight stitch with the bobbin thread and it is pulled to the bottom.
May 01, 2010 | Kenmore 15358
Model No. 15358. I am having problems with my
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Sep 04, 2009 | Kenmore 15358
Sears Kenmore Sewing machine model 15358 Just got this machine brand new yesterday. I've gone through the manual very carefully to make sure the machine is threaded properly. It's very similiar to my old...
The tensions must match ie. top tension =bottom tension. If the material is not sewn together tightly, that means the tensions are mismatched. Sewing machines will sew whenever the top and bottom tensions are equal (be it very tight or very loose).
We usually advise the customer to not touch the bobbin case tension. When that is not changed, all tension adjustments can be made from the top tension above the needle.
It appears that one of the two tensions (top or bottom) is much tighter then the other. I would reset the tensions to how they came, if you are unfamiliar with sewing machines this may take a little bit of experimenting until you get it back to a standard quality stitch.
The other option would be bring it to a sewing tech. A good mechanic should be able to adjust the machine and your tensions to your fabric (and recommend needle size for your thread/materials) in about an hour.
Apr 15, 2009 | Kenmore 15358
Top thread tension tight
March 12, 2009
kenmore 385.17922
i have started using my machine again (after several years) and am doing patchwork.. all has been fine, and suddenly the bottom thread (bobbin) is looping. i've adjusted the tension nob from 4 (where i had it) to 5...back to 4.. 41/2....3 1/2....5 1/2... on and on and the bottom thread still keeps looping.
i've read and re-read the manual...and the only suggestion it gives is to adjust the tension button.
it's not working...... what else can i try??
thanks
eva
Mar 11, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
762 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
