Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
U talk about cleaning the heat pump, well where is it and how do i get to it?
  • 61 Answers
The heat pump is a retagular box inside of the unit. Remove the upper housing, locate the box (about the middle of the machine), remove the six screws on the bottom and clean with a hard brisseled brush. Note: in most cases the lines inside should also be cleared. Put the machine back together and run 3 FULL tanks of HOT water through the machine. (To avoid future problems when you are done using the machine take it out onto a step and run a full tank of hot water through the machine to clear the heater and the lines.)
Posted on Apr 15, 2009
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
I have a Bissell preheat 2x which I have had for about 4 years. The cleaning solution and the water doesn't come out when I start to clean my carpet. I've unplugged the holes and cleaned the cleaner a
Clean the filters? Check your- User's Guide for locations. Or Contact Consumer Care at 1-800-237-7691
Filters are usually located under the Clean Water Tank Cap (looks like a screen) and The Flow Indicator Cap. Hope that helps.
Sep 09, 2014 | Bissell Vacuum Pro-Heat, Pro-Heat 2 6960W...
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
NO CLEANING SOLUTION IS DISPENSED WHEN i PULL THE HANDLE
the most common issue with the pro-heat not spraying is the heater being block up the link below is a video how to clean the unit.
http://www.youtube.com/watch?v=xNCEFwZzD1A&feature=related
Aug 18, 2012 | Bissell ProHeat Deep Cleaner Upright...
The indicator is flahing as to say it is heating up the water but continues to do so and never heats up
What kind of Vacuum has a water heater in it?
That is a new one-- unless we are talking about a steam cleaning machine?
Tell us more about the machine, and if you can see where the Heater is?-- and the power to it, etc., etc.
Dec 27, 2010 | Vacuums
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell pro heat clear view is not spraying when I press the trigger. what is the problem? I have check the belt and clean the machine. Is there something else?
I believe the water pump is broken. You can order a new one for about $22 and try to install it (it is located under the plastic near the cleaning solution holder). It requires removing quite a few screws, but if its just the pump, its easier than replacing the valves/solenoids under the water tanks
Oct 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
George
Hi.
No the switch for the pump will work without main vacuum switched on.
Your problem could either be faulty pump switch or faulty pump,
You should be able to get spares relatively easy from any independant vacuum repair shop.
Dont try currys etc they wont have a clue what your talking about.
http://dysonmanuals.llc.nu/
Chris.
Feb 08, 2008 | Numatic GVE370 Canister Wet/Dry Vacuum
Cleaner does not dispense
Check to make sure that the back end of the top housing is tight against the bottom, Sometimes they break loose. Make sure that the gasket at the bottom of the tank is on and is in place. Does the hand spray work? If it does then the heat inside the handle is plugged up. Pump belt broke or is slipping, could have a bad pump. The cap for the flow indictor is leaking air. There are alot off reasons why it may not be spraying.
Nov 10, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
139 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
