Question about Vehicle Parts & Accessories
Have a CHECKMAtE Model KD-70SPC alarm. Mechanic completely messed up the door locking mechanism. I don't know what he did while using the remote. I told him that I didn't have a manual (car is 1997) so, only touch the button # I and NOT to touch buttons II & III. Now my doors don't automatically lock AND THEY DON'T STAY LOCKED!! I come out in the morning to use my car and all door locks are in up position! HELP
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
  • 47 Answers
SOURCE: Disable or disconnect the factory installed alarm
should be a fuse for it, just remove it......
Posted on Jul 07, 2009
  • 53 Answers
SOURCE: I press the lock door/alarm activation button and
sounds like the remote is not program try programing the remote again
Posted on Jul 12, 2009
  • 1596 Answers
SOURCE: car alarm siren won't work but still can locked and unlocked the
REPLACE SIRIEN
SOURCE: Have 56 plate seat leon 1.6 .the alarm keeps going
I have Seat Leon 07 and my alarm has gone off loads of times in the last 18 months. The first time it was the window motor that went - went in under warranty and part replaced - it's now back in the garage getting the same problem fixed again. the neighbours are fed up with the alram going all times of the day and night. Hope this helps
Linda
Posted on Sep 18, 2009
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
Aug 18, 2012 | 1994 Volkswagen Golf
How can I disarm the Alarm. I bought my 97 Cabrio used (it didn't come with the remote) The Door locks also don't work. I can't drive it because when I turn the key the alarm goes off and it...
If you don't have the remote then its pretty much useless. I have seen at Pep Boys where they sell replacements for the factory/dealer installed alarms. Or just remove the alarm completely and reconnect everything the way it was.
Without knowing what brand alarm it is a person cannot honestly answer how to disarm it as they all work differently.
If you know a brand and model you may be able to find downloadable instruction on the manufactures web site.
Sep 08, 2011 | 1997 Volkswagen Cabrio
I can't shut my alarm for my dodge stratus rt 2002, I don't have a remote control
If it is a factory alarm it can be disabled by locking and unlocking either the trunk or drivers door. if it is an aftermarket alarm (one installed after the car was purchased) you would have to get a new remote and get it programmed or take the car to a mechanic and have it removed
good luck
Jun 04, 2011 | Dodge Stratus Cars & Trucks
It wont start security alarm went off and car locked down completely
use your remote key entry and or unlock the car from the drivers door only with the key to dissarm the alarm
Dec 27, 2010 | 1995 Buick Riviera
I have a 2005 reg toyota verso D4D every time I try using the central locking key it does not work when I try to use the mannual key the alarm goes off I can drive the car but cannot get the alarm to go...
Thanks for using FixYa.
Sounds like you have an Alarm remote battery problem. You need to change the remote's battery. The remote's battery gets a little bit of charge whenever you leave it for quite some time. A trip to your mechanic might have been long enough to give your remote's battery a little bit of charge that's probably why it works whenever you get to your mechanic's place. But after that, you've used the little bit of charge that the battery has then It will not work anymore after you get home. Try leaving the remote unused for at least an hour or two then try to use it. Im sure it will work for a bit. Just get the remote's battery changed.
I hope this helps. Have a nice day.
- HotRatchet
Mar 14, 2010 | 2003 Toyota 4Runner
1999 jeep grand cherokee will not start because of alarm
Sounds like the brain quit on you, I would uninstall it or completly disconnect it and have it looked at. Make sure you reconnect the factory wires and start over. Also check the ground for the alarm as it will draw current from what ever wire it can and cause all kinds of things.
May 26, 2009 | 4-Button Remote Start/Keyless Entry with...
Does not cherp
Is your perhaps alarm in "valet mode"? I've got a Checkmate on my Honda, and I can turn valet mode on/off by putting the key to Accessory, then pushing the black button under the left of the steering wheel. The alarm chirps when you switch the mode.
May 23, 2009 | 2000 Buick LeSabre
How to disable alarm system
I have 96 dodge caravan and I need to disable the alarm system too and I don't know how!
Apr 20, 2009 | 1996 Dodge Caravan
Car remote alarm system
THE VALET SWITCH SOULD BE IN THE DRIVERS KICK PANEL OR AROUND THE LOWER SIDE OF THE STEERING WHEEL
Apr 16, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
555 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
