Question about ASUS A7V133 Motherboard
Won't stay on long starts the just stops
A7A133 motherboard
  • buffalonyman
    buffalonyman May 11, 2010
    Have you checked the power supply?
  • 922 Answers
I am sorry to say this but the problem you are describing is usually caused by a board failure. Given the age of the motherboard it is likely that it is finished.
However, before giving up, make sure that battery on the motherboard is good, all of the hardware is seated and plugged in tight. You could also try another power supply.
Posted on Aug 08, 2009
Asus p5nd motherboard won't start when power button is pushed, but the motherboard light stays on..
Most probably your power supply. An SLI rig will draw a lot of power for the graphics and for a power supply in a system like this to have lasted 5 years is amazing. They don't last forever. You could buy a PSU tester (about 10 GBP) and confirm it. But if you have to buy a new one look for one that is at least 25percent more powerful than your old one and has at least a bronze efficiency rating. (silver would be better) and buy one from a known brand such as Antec, Chillmaster, or OCZ.
Mar 16, 2013 | ASUS P5ND nForce 750i SLI Motherboard...
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
The cables won't stay in the camera whe I'm
Stop using the camera for downloads and start using a separate card reader. typrice_255.jpg
Aug 31, 2011 | Sony Cameras
Won't start-If I take the positive battery terminal loose and the bike stays running does it mean the charging system is working?
Yes but not recommended, as it may spike the regulator and cause it to stop charging.
Better to check battery voltage with a multi meter.
around 12v engine stopped , and will rise when engine is started and revved to 13 or14v
Aug 12, 2011 | Suzuki Boulevard C50T Motorcycles
System won't boot
Your motherboard has a chassis intrusion detector. This just means that someone opened your computer case. Since you did this to change drives all you need to do is reset the detector and you'll be fine. You should have a setting in bios to reset the detector. Hope this helps.
Apr 08, 2009 | ASUS A7A133 (A7A133/WA) Motherboard
Forgot CMOS password
Take battery out for 3min and put back
Feb 15, 2009 | ASUS A7A133 (A7A133/WA) Motherboard
ASUS A7V133 Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
