Question about Dryers
Thermal cut-out keeps cutting out so dryer isn't drying threr must be a blockage some where but dont know where empty the blockage can you help me? its a teka washer dryer
  • 15,935 Answers
It's always a good idea to replace both the thermal fuse AND safety thermostat when the fuse is found open. In fact, most manufacturers supply these in kits that include both parts. The thinking is, if the thermal's blown, it's a pretty fair bet that the safety tstat's been doing a LOT of cycling, and is most likely really stressed.
There is an obvious problem with your dryer (or venting) if this problem continues to happen.
One final note on these: if you find your thermal fuse (or element) open, before replacing it, be sure to check the airflow out your dryer’s vent system. Even though these devices do ‘wear out’ with age, poor airflow’s the #1 cause of failure of these devices, and if your vent’s partially clogged, a new thermal won’t last very long, but will do its job again, and leave you ’cold’ (a new element won't last long if the vent's clogged, either).
To check for blockage - remove the dryer vent right where it exits the machine. Inspect inside the vent tube, and the exhaust tube.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 15, 2009
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
Samsung electric dryer keeps burning up thermal cut-off thermostat
I am not familiar with the model.
That the thermostat keeps failing, due presumably to overheated/burned contacts does indicate the element is drawing too much current. I can think of no other reason to explain your experience except possibly there is excessive arcing at the contacts as they open and close. The addition of a suppressor capacitor might help but the big question to be answered is why is there too much current or excessive arcing...
I can only suggest you thoroughly examine the heating element looking for breaks and accidental short circuits between the coils of the element or connecting wires.
Feb 28, 2017 | Dryers
Dryer still runs it just isn't getting warm
The heating element is wired in series with a thermal cut-off and a high-limit thermostat both located on the heater housing.The thermal cut-off blows open when the high-limit thermostat fails to cycle off in order to regulate the heating element temperature. When the thermal cut-off is blown, power to the element is cut-off and the dryer will not heat. Replacing both thermal cut-off and the high-limit thermostat if the former is indeed blown. Click on the links below for the troubleshooting and repair details.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Front Bottom Panel) Running But Not Heating
Jun 18, 2011 | Whirlpool Dryers
I ahve a duet gas dryer and it will not get hot
Now did this happen all at once or did it slowly dry clothes slower and slower and then just quit? If it happened slowlt it is because you have some sort of ventalation blockage withing the dryer itself or in the wall of your home. When this happens it will the blow the thermal cut off and this will need to be replaced. If it happened over night then it could be the heating element or the thermal cut off & thermostat. All these can be checked with a volt meter using the setting for continuity.
Mar 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Dryer fails to dry clothes fully, but the clothes feel warm; could this be an element issue?
If the clothes are warm I wouldn't think the problem is the heating element. Check the venting from the machine to the outside and make sure you do not have a blockage somewhere. If it is clear, you probably need to replace the thermal cut off.
Nov 09, 2009 | Roper REX4634KQ Electric Dryer
Dryer not drying, but running?
could be as easy as changing the element or thermal cut out .... element number is 279838 and thermal cut out is 279769 check for 220 volts at element if you have it the element is bad if not the thermal cut out is bad ... got both of them on sale at whirlpoolpartssurplus.com most people just buy both and get it done!
Mark
Jun 26, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesn't dry
YES, most defintely. This typically causes the dryer to overheat and eventually blows the thermal cut-out or heating element.
SYMPTOMS:
Dryer runs, but does not heat - possible bad heating element or thermal cut-out.
Dryer does not run at all - possible bad door switch, blown thermal fuse, timer or drive motor.
Does your dryer exhibit any of these symptoms? Please post back and let me know.
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Roper household dryer not heating
you can unhook themal cut out or themostates hook the two wires together tape or make sure they dont touch anything and test dryer.. if heat comes on thats the problem
Sep 15, 2007 | Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
130 people viewed this question
Top Dryers Experts
