Question about LG M228WDP-BZ 22 in. LCD TV
LG m228wd TV can't change input
LG m228wd TV, Every time I attempt to change which input to view, the tv instantly reverts back to DTV, I can't do anything about it!?
SOURCE: Scanning dtv channels
go to menu setup and do the full system reset setup option... Then before you scan for channels make sure it is set to cable... This fixed the problem for me.
Posted on Feb 12, 2009
a-team2009
  • 4 Answers
SOURCE: TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Posted on Mar 01, 2009
jojack2k5
  • 34 Answers
SOURCE: HDMI Cable dosn't work? AVI only. WHY?
chk factory outgoing settings in service menu
Posted on Apr 29, 2009
  • 141 Answers
SOURCE: wont tune in dtv
Does it have a digital tuner? If not, you need a set-top box. If that's covered, you may need an antenna.
Posted on Aug 05, 2009
tvservice306
  • 458 Answers
SOURCE: LG 42LC2DR - tv channel picture & freezes Intermittently
replaced main board
Posted on Aug 13, 2009
When viewing TV with DTV, the sound will occasionally mute right after the clipping in a program. Just like the function that protects the speakers from loud sounds. (This function is OFF) The sound comes...
Just try connecting the input to another TV and check whether the same problem comes. If it does, the problem is with the input. If not, the signal strength is not good enough to the microcontroller IC to switch off the mute. Normally when the signal is missing or weak, audio mute gets operated.
Jul 12, 2012 | LG 42le5300
What is dtv mode
If reset did not cure it DTV is usually the input for HD coming out of a box---If the set has more than one HD input have you tried hooking to another one?
Another suggestion would be to check with LG to see if this model has any issues related to your problem or if it is possible to upload and then download a software upgrade into this set (some sets can and others are not set up for this.)
Regards, SD TECH
Mar 13, 2012 | LG Televison & Video
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
I can't get a sound from my yamaha rx-v367. my tv is lg le5310
Last update: 05/02/2008
Connect the audio outputs jacks from the TV to any available audio input terminals on the Yamaha receiver, other than the phono input. You can use any analog audio Left (White) and Right (Red) inputs on your receiver such as the DTV/CBL, SAT or VCR input. There are no special settings needed on the receiver, other than selecting the correct input. There may be some settings that will need to be changed on the TV. Consult the TV ownersEmanual for setting up the TV to output audio to an external source. If youre TV has a digital output (Optical or Coaxial) it can also be run to one of the digital inputs on the Yamaha receiver, such as DTV/CBL or DVD. There may be some settings that will need to be changed on your TV. As always, consult the TV ownersEmanual for setting up the TV to output digital audio to an external source.
NOTE: When the source of the audio signal is coming from an HDMI device connected to the TV, the TV may not output in 5.1 surround sound.
Jan 01, 2011 | Yamaha RXV367 Receiver
LG LST-5100P set top box does not display menu with an older ( 1998) tv set. Cant select aspect ratios . All I can do is change channels. Any ideas? Rod
Hi Rod,
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
LG LST-5100P User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 22, 2009 | LG LST-4200A DTV Receiver
Bush TV and Setting Default Inputs
Not an expert on this model but generally if you switch the TV on by pressing the remote's power button it will come back using the input you previously used. If you press a channel button it will come back to DTV.
Jul 19, 2009 | Televison & Video
Yamaha Receiver loses audio when changing DTV stations
I believe changing stations is triggering the protection on receiver. When you go to another input and back you give time for the protection circuitry to release speakers again. Try muting your receiver before changing channels. Good luck!
Nov 21, 2008 | Yamaha RX-V463 Receiver
Make TV go to 1080p
make sure that you have your HD source hooked up to the correct input on the tv. you are going to want DTV as the input.
Feb 13, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Oct 19, 2007 | Mitsubishi WS-55809 55" Rear Projection...
LG M228WDP-BZ 22 in. LCD TV Logo
274 people viewed this question
Computer Repairing
Computer Repairing
