Question about Sony PlayStation Portable (PSP) Console
Cant get computer to recognize the psp
I plugged the psp into the computer to download music and it says it is not connected what do i need to do
The usb cord is not working probably
Posted on Dec 25, 2009
  • 64 Answers
First, make sure the music you are wanting is in mp3 format
Hook up your Sony PSP to your computer via a USB cable. Turn on the PSP and put it in "USB CONNECT" mode (it should display the words "USB CONNECT" on the PSP display during the entire time you're transferring files, and plug it in if you don't have a fully charged battery).
If your computer complains that you are connecting a high-speed USB device on a low-speed USB port, try unplugging it (which is to say, take your PSP out of "USB CONNECT" mode, then unplug the cable from the PSP) and plugging it into a different USB port. Somewhere on your computer you have a higher-speed port, which you should certainly use if you can. If not, or if you can't figure out which port is USB 2.0, then you should be able to safely ignore the warning message and proceed anyway. Once you rehook up your PSP, do make sure you remember to put it back into "USB CONNECT" mode).
Your PC or Mac should just magically show a new removable hard disk on the desktop (or, if needed, go to My Computer to find it). On a Mac it'll probably show up as a device called "Removable Drive", but on a PC it can show up as drive E:, F:, G: or whatever else is the next available drive name on your computer. If it doesn't show up and you're running Windows XP, then you might need to search for the proper driver, which is hopefully an option. If you're running an earlier version of Windows, you're kinda on your own because earlier versions don't support pluggable hard drives. There's an untested Windows98 driver you can download from Interia.pl, but I haven't heard from anyone whether it actually works or not.
Once your PSP shows up on your computer, you should be able to navigate the different directories to find a folder called MUSIC. That's where you want to drag and drop your MP3 files, so do so now, realizing that each music file typically takes up 2-3MB of space, so the default 32MB Memory Stick Duo that came with the Sony PSP is only going to be able to hold about one CD of music before it's full, and that's assuming you don't have any game saves on it. Instead, you might consider buying a bigger Memory Stick: I have a 512MB one that gives me plenty of space and it didn't cost much (Amazon.com, for example, sells this funky green 512MB PSP-compatible Memory Stick for less than $40, with free shipping).
(If you don't have a "MUSIC" folder on your PSP then you might need to have the PSP unit itself reformat the memory stick (rather than your PC) so that all of the folders are setup properly.)
Once you've copied your music files onto your Sony PSP device, you should be done. Take the PSP out of "USB CONNECT" mode, then unplug the cables, hook up headphones so you can hear the PSP audio, and then go to the MUSIC area on the PSP.
One of the items listed in "MUSIC" is something called Memory Stick. Your songs are in that folder. To get to them, move the highlight bar to "Memory Stick" and press the "X" button:
You can see the "X button on this photo: it's the lowest of the four buttons on the right side control area.
You should then move into the Memory Stick music area and see all of your MP3 files. Click on one to play it!
Hopefully these detailed instructions will help you avoid tossing your PSP out the window. If not, well, let me know when you'll be tossing it and maybe I can catch it and use it as another test device. :-)
Please Rate Me if this Helps
Posted on Apr 15, 2009
Dont kno how to put music and videos in my psp
Putting music or videos on the PSP is a fairly simple and straightforward process.
What you'll need:
  • a mini USB to USB cable (to connect the PSP to the computer)
  • a memory stick (to store your music and videos)
Instructions:
  1. Put the memory stick in the PSP.
  2. Connect the PSP with the mini USB to USB cable to the computer
  3. On the PSP, go to the settings menu and select "USB Connection."
  4. Your computer should recognize that a device has been connected to it, open up the device (your PSP) inside a file viewer, such as windows explorer. There should be a few folders here one named Video and one named Music.
  5. Add the music and video files to these folders, and press O(circle) on the PSP to end the USB Connection.
  6. If all has gone right, and the files are the correct formats, you should be able to enjoy your music and videos on your PSP.
Mar 13, 2011 | Sony PlayStation Portable (PSP) Console
About music
conenct the PSP to USB and then set it to USB mode.
access your "my computer" then clcik on the PSP icon on your my computer screen
you will be able to see folders in there, one is music, just copy the music file from your computer then paste it in the "music folder in the PSP.
Aug 17, 2008 | Sony PlayStation Portable (PSP) Console
Cant seem to be able to download music onto it off computer didnt get any instructions with it
Hi Oligan10,
Attached below are 10 easy steps to get you started in playing your favorite music using your PSP.
step 1 Take a USB 2.0 cable and connect the PSP to your computer step 2 Press the home button on the PSP step 3 Use the left and right buttons to find Settings ( select by pressing the X button ) step 4 Select USB Connection -Your computer will notify you that a new USB device has been connected This should show up as a new hard drive with a corresponding letter identifier step 5 On your computer, select the correct drive letter and open PSP file system step 6 Create a new folder and call it PSP step 7 Go inside this new PSP folder and create another folder. Name it MUSIC step 8 On your computer hard drive, Select the MP3 music files that you want to transfer and save it into the MUSIC folder that you have just created step 9 Disconnect the PSP from your computer by pressing the O button step 10 Unplug the USB cable.
To View and Play the downloaded music on your PSP :
- Use the left and right buttons and select MUSIC - Select Memory Stick by pressing the X button You should see all the music files you have just transfered to the PSP.
I have attached a link to the PSP Manual, should you need more information about your PSP. http://www.fixya.com/support/p201358-sony_playstation_portable_psp_console/manual-16250
All the best to you my fellow PSP enthusiast.
Jan 26, 2011 | Sony PlayStation Portable (PSP) Slim...
HOW TO ADD MUSIC TO PSP
Adding music is rather simple. First, you have to connect your PSP to your PC via a USB Cable. Once it's plugged in, click on USB Connection on the PSP Menu. Your computer will recognize your PSP and ask what you want to do with it.
Open up your PSP folder and open the folder called "MUSIC". Open the folder on your computer that has the music you want to add. Click and drag the files over to the PSP. Once the transfer is complete, disconnect your PSP and goto the Music tab on your menu and select "Memory Stick''. All the music you uploaded should be accessible.
Jun 20, 2010 | Sony PSP-3000 Silver Console
I dont know how to down load music off my computer
It's easy just download a limewire and after installing it, search for your fave music and download. enjoy!
Mar 06, 2010 | Sony PlayStation Portable Silver Console
How to add music to your PSP
You will need to plug the psp into your computer,
Then selected usb mode
Wait a few minutes until the computer recognizes the device.
Go to your desktop and open "My Computer" and look for your PSP.
You will need to create a new folder called music and then you can just drag and drop your music files.
If that sound a little to difficult there is a freeware application that will put music on it for you. http://www.download.com/PSP-Shuffle/3000-2248_4-10407187.html?tag=lst-0-2
Good Luck!
Nov 20, 2009 | Sony Video Game Consoles & Games
How do i download music to psp
I have downloaded music from my PC to PSP. You need a USB to mini-USB cord. Plug the cord into both the PSP and PC. The PC should recognize a new "mass storage device". Open up that ballon on your PC and name that port with a file name. Then, Go to where your music is stored on your PC and "send it" to the PSP file and it will download the music to your memory stick. Good luck!
Nov 06, 2009 | Sony PlayStation Portable (PSP) Console
My computer cant recognize my sps
Before you plug it in,
Make sure the PSP is in USB connect mode.
Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's not this is how you do it:
On the main menu, scroll all the way left to the "Settings" menu. Then select "System Settings." Then scroll to "Format Memory Stick" and press X.
May 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Cant download music
try NOT going through media player as it tries to convert any audio. keep your files as mp3. preferably stored in "My music" file on your computer. then when you connect your psp via USB go to "open folder to view files" then open psp/music file. leave it open and open a "My computer" window my documents/my music, then just click and drag to psp/music file.
Apr 25, 2009 | Sony PlayStation Portable (PSP) Slim...
Downloads
find the music on your hard drive then copy it to the music folder on your psp.
Nov 18, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
225 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
