Carver PM900 power amp with hum/buzz
I have a Carver PM900 power amp with what sounds like a ground hum/buzz in both channels. My repairman here in Atlanta can't figure it out after two hours of scoping and manual/schematic research. The best he can come up with is that it may be some kind of power supply issue. any suggestions? Thanks, Jerome.
  • 682 Answers
1-shut down all flourecent lamp and check.
2-check for your cables in a good condition and no touching of wires to the body of amp.
3-connect(ground loop isolator)code number(270-054)from radio shack near you and connect it between your audio device(like cd player and amp)
Posted on Apr 15, 2009
  • Jonathan Ansell Dec 08, 2010
    The buzzing is inherent in the design of the PM range. It is due to the triac in the power supply.
    You may wish to try replacing or improving the passive snubber network around the triac.
    Personally, i prefer to add a large mains filter (similar to those found in washing machines) to the mains cable.
Is it normal for carver power amps to have a slight hum? I have a carver-55x
Hum can come from a jillion different places. Is this hum coming from the unit with no speakers connected, or is it heard through the speakers? What sources are being used? What cables? Are thereany common sources of interference near? Troubleshooting is difficult without much information.
Jan 11, 2015 | Carver Audio Players & Recorders
Loud buzz on both channels with new turntable and phono
The ground wire needs to be attached. The hum is a result of a bad ground.
Jul 12, 2014 | Audio Players & Recorders
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
Power supply noise lg 42LV3730?
If your tv uses rca a jacks to connect it up to the reciever, You coul try what is called a ground loop iceilator, It hooks up to the patch cord,If they are still availible.They were use on car Stereo,s when you have a amp hook up to it,In some vehicles you would get a ground loop hum. Radio Shack might still sell them. You could try one.It work for me with a (Carver) Power amp that i use to own.
Oct 19, 2012 | Audio Players & Recorders
Carver amp started making a low fluttering sound.
I have a Carver amp which developed a "hum" also. As a troubleshooting step only (long term this is NOT a solution) you can use a ground plug adapter that removes the ground lug from the unit. This is an adapter that has THREE (Line, Neutral, Ground) female sockets for the amp to be plugged into, and TWO male plugs to go into a wall socket. If the buzz goes away, you've got a leaky capacitor in the Power Supply section of the amp. It will take some doing to actually fix the problem, but this will narrow down the cause.
May 27, 2010 | Carver PM950 Amplifier
I have a low hum with my Carver M 400 amp. How do
If it is accros both channels (on every imput) your best bet is to replace the large electrolytic capacitors in the power supply, these filter out the 50/60 Hz hum from the mains, so they might have failed. Electrolytic capacitors anywhere are good at causing hum!
If they are say 4700UF at 50Volts, you can replace them with any UF rating higher than that, and the same with the voltage. Never go lower than the ratings marked. Also keep an eye out for the temperature rating. It will be given marked "c". If it says 105C then replace with one the same, though it will work with a lower rating it will fail faster than normal. The only problem with electrolytic capacitors is 'space' to fit as they come in many different sizes. So bare that in mind when you a tracking down replacements.
Mar 22, 2010 | Audio Players & Recorders
Carver CT-28v Tuner preamp - Has a hum/buzz (soundls like a ground loop) that is heard as soon as the unit is turned on. Does not increase with volume, just stays the same and is continuous. Changing...
Reverse the polarity of the AC plug and try it. Is there a headphone jack on the preamp? Try headphones with the preamp standalone without the amp attached.
Are you sure the preamp is the problem? I assume you also have an amp or you wouldn't hear anything. Power up the amp with nothing but speakers attached. Hum??? It's in the amp. No Hum? Attach just the preamp with no external components. Hum now? It's the CT-28. Turn it off an exercise every switch and knob throughout its range numerous times. Try again. Still humming? Manipulate source selections, Tape Monitor, everything.
Nov 19, 2009 | Audio Players & Recorders
Carver pm-1.5 power amp has constant buzz in speakers
carver pm-1.5 power amp has constant buzz in speakers, try removing ground jumper on back
Sep 13, 2008 | Audio Players & Recorders
932 people viewed this question
 Grubhead
Grubhead
