Question about Dell Inspiron 8200 Notebook
Mouse pad My Dell Inspiron 8200 mouse pad is not working properly. It either moves to the lower left hand corner or upper right hand corner. Other times it works just fine. can you help me. Thanks alot
  • 432 Answers
You would be better off using an optical mouse that has a usb or ps2 connector ( depending on what your laptop supports ) usb would be better though less chance of pins bending as there are none on a usb connection ( at least not like a ps2 connector )
Also download the latest drivers for the touchpad and make sure that the scrolling options for or on the touchpad are not configured too thickly which will be in the touch pad settings.
Posted on Apr 15, 2009
My laptop Dell inspiron N4010 touch pad is not working.. wats the solution
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 11, 2012 | Computers & Internet
Where is volume control on dell laptop
Hi there! this might work :)
1.Click once on the speaker icon in the lower right corner of the laptop screen on the task bar to open the volume control.
2.Click and hold the slider control with the left mouse button or the left button on the touch pad, then drag the control higher to increase the volume on the built-in speakers.
3.Click the "Start" or Microsoft flag button in the lower left corner to access the Dell's Control Panel. Click twice on the Control Panel.
4.Click "Hardware and Sound" then click "Adjust System Volume" under the "Sound" listings.
5.Click and drag the slider control to adjust the sound level, then click the "X" box in the upper right corner to close the application.
Sep 30, 2011 | Dell Tablets & eReaders
The touch pad was working and now all of a sudden its not
Check your model for a mouse pad disable key. A lot of times it is right above the mouse pad (and is easily bumped) or a function key. It generally looks like a symbol of two mousepads with the second one having a line drawn through it.
Try pressing this button or holding in the Fn key (lower left hand corner) and pressing the function key and see if that resolves your issue.
If not make sure mouse drivers are installed and working properly.
If none of this helps, please post your model and Windows version.
Please leave feedback if this was helpful.
Mar 23, 2011 | Computers & Internet
Mouse pad on dell inspiron 1501 not responding smoothly to my request. I am very disappointed with my two year old dell. Need help asap.
This is a common problem with laptop touch-pads.
You will have to use an external mouse. You can purchase a USB mouse which should solve your problem.
Dec 30, 2009 | Dell Inspiron 8200 Notebook
Key pad doe not work
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
May 26, 2009 | Dell Inspiron XPS Gaming Mouse Pad KU170
Mouse pad buttons not working properly. i have a dell inspiron 6400 and my left mouse button isnt working properly! the right one works fine, please help me!!!
If the left mouse button is not working, then it is most likely the microswitch in the button has failed. To fix, you will need to replace the palmrest assembly
Dec 17, 2008 | Dell Inspiron 6400 Notebook
Screen image is upsidedown
Hold down the CTRL+ALT keys, and hit the Up arrow on the keyboard.
Aug 01, 2008 | Dell Inspiron 710m Notebook
Mouse moves on its own
its actually the blue thing that u can also controll with so just take th elue cap of and wiggle it around n it should stop
Jan 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell laptop pointer problem
This is a very common problem for most Dells this age.
You can try this repair if you feel comfortable.
Remove the keyboard by removing the power button bar (just gently pry up from the right side working left)
re-insert the mouse cable which is coming from the pad/palm rest. Re-assemble.
Check if all the screws on bottom of the unit are tight, especially around the palm rest area.
Good luck
Nov 05, 2007 | Dell Inspiron 2200 Notebook
Dell Inspiron 8200 Notebook Logo
232 people viewed this question
Alun Cox
