How do I take out the agitator?
How do I remove the agitator since a belt is stuck underneath.? There is a shoelace twisted underneath the agitator of my GE S3700G2WW washer. I need to remove the agitator to get it out but I can't see the bolt because there is a plastic cover over it. How do I remove the plastic cap and then the agitator?
  • funny_face78 Apr 15, 2009
    Nevermind. The whole agitator on the S3700G2WW simply pulls off. No need to unscrew it at all. Silly me.
  • 234 Answers
I'm not sure if this is the same as your machine but here is a link to a possible solution:
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
I hope that this solves your problem.
Posted on Apr 15, 2009
Sock stuck under agitator
Good Afternoon Haley - Based on the model number posted above, it shows that you are speaking about a front load washer. Is that correct? If so, then generally speaking front load washers do not have an agitator. If a sock is caught underneath it is typically because it got caught in between the door and drum because the seal is either damaged or off the track. If you have a top load washer, you may try to twist the agitator and then pull it out to remove it, as you would for maintenance cleaning.
Jun 24, 2013 | Frigidaire Affinity ATF7000E Front Load...
Agitator keeps rising up and washing getting stuck/twisted underneath
The nut that holds the agatator on has come loose and is properly floating around in the agitator.Or it just needs to be pushed down to lock it in place. At worst the bolt and nut has rusted away. (repair man)
Dec 21, 2010 | GE Washing Machines
Agitator is not working during wash and rinse cycles, and there is a slipping noise from underneath machine
You need to pull the agitator up and see if it's inner teeth have been worn smooth or something broken where it engages the steel shaft from the transmission. If everything looks okay then I am afraid it could be a bad transmission.
Sep 14, 2009 | Washing Machines
Shoelace got stuck in top of dryer, we'ved triped breakers and it won't turn on. What's wrong? Help!
IF you have removed the entire shoelace and it is now free and clear to turn by hand and is really easy to turn it may have burned a belt. IF it is belt driven which most are? Contact your repair guy and ask if your brand make and model is belt driven? IF it is chances are that is the problem.
Good Luck
Al
Sep 11, 2009 | Maytag Dryers
Can't get the fabric softner cap off
Don't feel foolish as im sure your not the only one this has happened to. to remove the agitator cap you must lift it off, apply slight twisting to it while your doing this. soap can gum it up so you may have to use a straight screwdriver to assist you. once you have done this, there should be EITHER a set screw for an allen key on the SIDE of the agitator OR a 3/8 hex screw in the center or the agitator. there is a spring under this screw so remove both and the agitator should lift staight up. use an old belt underneath the base of the agitator for better results. i hope this has answered your question.
Thanks
Aug 08, 2009 | GE WJRR4170E Top Load Washer
I believe for that model, to remove the agitator you must reach inside with both hands and firmly grasp the lower part of the agitator and pull straight up. It may be a little difficult but should come off. Make sure you get it all the way back down when putting it back on. Hope this helps.
Apr 13, 2009 | GE WBSR3140DW Top Load Washer
How to remove the agitator??
remove agitator cap ,,looking down in agitator removre the plastic seal with a firm yank,,now you can see the agitator hold down nut,,remove that bolt with 1/2 inch nut driver or wrekit,,pull agitator..if clothes is jammin it down take you belt and slide under agitator,,and pull booth ends ,,but away from your fast ,may come up fast..always unplug
Oct 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore elite washer not agitating properly
pull off fabric softner dispenser ..some twist off others pull blue ring up and then dispenser up..under neath remove the cover by prying cap or pulling up on tabs..remove 7/16 bolt or on some use 1/2 in drive extension to twist out retaning bolt pull top off and replaced the agitator dogs underneath ..part#80040
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Power brush SEB234/236
Hi Clyde,
Before you start, unplug the vacuum from the wall socket.
First remove all the shoe laces from the beater brush. Then make sure the belt in installed correctly. If this doesn't correct the problem, open the unit and find any fuses that it may have and replace any that are blown. That sould correct your problem. It sure seems that vacuums get hungry for more than dirt at times. lol Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vacuums
Washing Machines Logo
394 people viewed this question
Top Washing Machines Experts
